Need confirmation on this integration problem
  • Thread starter Thread starter jzq
    Integration
The discussion revolves around the integration of the function e^(5x). Participants are examining the correctness of the integration process and the inclusion of the constant of integration.
  • Mathematical reasoning, Assumption checking
  • Participants are confirming the integration result of e^(5x) and discussing the necessity of including the constant of integration. There are also questions about the variable of integration used in the expression.
Some participants have provided guidance on checking the correctness of the integration by taking the derivative of the result. There is an ongoing exploration of the implications of omitting the constant and the variable of integration.
There is a mention of the linearity of integration and the importance of specifying the variable of integration, indicating that assumptions about these aspects are being questioned.
jzq
Here's the problem:
[tex]\int e^{(5x)}[/tex]
This is what I got (Correct me if I am wrong.):
[tex]\frac{1}{5}e^{(5x)}[/tex]
Or is it just the same:
[tex]e^{(5x)}[/tex]
jzq said:
Here's the problem:
[tex]e^{(5x)}[/tex]
You are sort of right. I think you mean
[tex]\int e^{(5x)}dx = \frac{1}{5}e^{(5x)} + c[/tex]
Yes, I forgot to add the constant, but that's what I meant.
So I am correct then?
Yeah. In general, if you want to check yourself, just take the derivative of what you just integrated. If you get back the integrand, then you know you solved it correctly.
jzq said:
Here's the problem:
[tex]e^{(5x)}[/tex]
Linearity of primitive functions:
[tex] \int f(x)\ dx = F(x)\ +\ C \Rightarrow \int f(ax)\ dx = \frac{1}{a} F(ax)\ +\ C,\ a \in \mathbb{R}\ \backslash \ \{0\}[/tex]
Thanks guys!
You also forgot to include the variable of integration for your integral. You need to know what the integration variable is. It will not always be dx, so you should be careful with it.
  • · Replies 50 ·
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 25 ·
