Need help finding Diagonals of a Rhombus
  • Context: MHB
  • Thread starter Thread starter thatbluegsx90
This discussion focuses on calculating the diagonal measurements of a rhombus-shaped terrarium cover. The diagonal distance "A" is determined to be approximately 11.66 inches using the Pythagorean theorem, where A = √(72 + 64). The distance "B" across the top cover is confirmed to be approximately 8.485 inches, calculated as 6√2. The dimensions of the terrarium include a back height of 16 inches, a front height of 8 inches, and a base width of 6 inches.
  • Understanding of the Pythagorean theorem
  • Basic knowledge of geometry, specifically rhombus properties
  • Familiarity with terrarium design concepts
  • Ability to interpret geometric diagrams
  • Research advanced geometric calculations for irregular shapes
  • Explore terrarium construction techniques and materials
  • Learn about the properties of rhombuses and their applications in design
  • Investigate tools for precise measurement and cutting of glass
DIY enthusiasts, terrarium builders, geometry students, and anyone interested in precise measurements for design projects.
thatbluegsx90
Not sure where exactly to post this but I think it fits in this category...I recently got interested in making a Terrarium and plan to make the glass enclosure myself.. for the life of me without having the physical thing in front of me I can't figure out one of the diagonal measurements of the top cover.. I apologize for the rough drawing but I'm looking for what A and B are(didn't mean to put the X in there)... I'm about 60% confident that B is 8 1/2 but I has been a while since I've done anything related to this
Mathematics news on Phys.org
From your middle, side view, the back height of the terrarium is 16", the front is 8", and the base is 6". If you draw a line from the top of the front perpendicular to the back (so parallel to the base) you have a right triangle with height 16- 8= 8" and base 8". By the Pythagorean theorem, your distance "A" satisfies A^2= 8^2+ 8^2= 64+ 64= 120. So A= \sqrt{120}= 2\sqrt{15} or about 11" (10.954...). Your distance "B" is just the distance across which is 6+ 6= 12".
[TIKZ][scale=0.5]
\coordinate (A) at (-5,2) ;
\coordinate (B) at (1,3) ;
\coordinate (C) at (6,1) ;
\coordinate (D) at (0,0) ;
\coordinate [label=left: $B_1$] (E) at (-5,14) ;
\coordinate [label=above right: $A_1$] (F) at (1,19) ;
\coordinate [label=right: $B_2$] (G) at (6,13) ;
\coordinate [label=left: $A_2$] (H) at (0,8) ;
\draw [very thick] (G) --node
{$12$} (C) --node[below] {$6$} (D) --node[below] {$6$} (A) --node
{$12$} (E) -- (H) ;
\draw [very thick] (E) -- (F) -- (G) -- (H) --node
{$8$} (D) ;
\draw [dashed] (A) -- (B) -- (C) ;
\draw [dashed] (B) --node
{$16$} (F) ;
[/TIKZ]​
In my picture, the distance between $A_1$ and $A_2$ is your distance $A$, and the distance between $B_1$ and $B_2$ is your distance $B$.
Both of the points $B_1$, $B_2$ are $12$ inches above diagonally opposite points of the base of the terrarium. So the distance between them is $6\sqrt2$, which is approximately $8.485$ (close to your estimate of 8 1/2, but a bit less).
The horizontal distance between $A_1$ and $A_2$ is again $6\sqrt2$, but there is also a vertical separation of $16 - 8 = 8$ between them. It follows from Pythagoras's theorem that $A = \sqrt{72 + 64} = \sqrt{136}$, which is approximately $11.66$.
If it helps you in cutting the glass, the sides of the rhombus are approximately $7.2$ inches. The angles at $A_1$ and $A_2$ are almost exactly $72^\circ$ (and the angles at $B_1$ and $B_2$ are almost exactly $108^\circ$).​
  • · Replies 30 ·
  • · Replies 24 ·
