Need help in solving thermo problem
  • Thread starter Thread starter Ossdon
    Thermo
The discussion centers on heating water for underfloor heating using a fireplace, with a focus on determining the necessary length of a copper pipe placed inside the fireplace. The fireplace temperature is approximately 1000°C, and the goal is to heat water from 23°C to 55°C. Concerns are raised about using copper due to its melting point of 1085°C, suggesting that steel might be a better option for the pipe material. The conversation emphasizes the need for appropriate materials and calculations to ensure the water reaches the desired temperature without compromising the pipe's integrity. Overall, the discussion highlights the technical challenges of integrating a fireplace with underfloor heating systems.
Ossdon
Hi
The thermo problem is as follow:
I have a fireplace and I have an underfloor water pipe heating. currently the underfloor water is heated by gas burner.
I want that the water will also be heated by the fireplace, so I plane to place a chopper pipe inside the fireplace and run the underfloor water trough it.
I need to find out what should be the length of the chopper pipe inside the fireplace.
Here are the parameters:
Fireplace temperature = ~ 1000'C
Chopper pipe diameter: Inside = 11mm, Outside = 13mm.
water speed in the pipe = 2500L/hour.
water temp at the start of the pipe is 23'C.
water temp at the end of the pipe should be 55'C.
what should be the length of the chopper pipe inside the fireplace so water entering the pipe in 23'C exit the pipe in 55'C?
Whats I'm asking is, how long it takes for a 23'C water to heat up to 55'C in a 1000'C oven.
Please replay with the relevant equations and the way to solve the problem.
Tnx a lot
Ilan
Science news on Phys.org
I take it that 'chopper pipe' is actually copper pipe, that is pipe made from copper (Cu).
I would advise against using copper, especially since its melting temp. is 1085 C. You also could not use solder to join any pipe sections, since the M.P. of solder is much lower than the M.P. of copper. You would probably need to use steel pipe, since that material can be threaded or welded and doesn't work-harden like Cu.
Yes, sorry not chopper but copper.
The pipe with running water inside will never rich the 1085'C.
there will not be any solders or joints.
Tnx
  • · Replies 40 ·
  • · Replies 26 ·
10K
9K
10K
