Need Help Transposing the pressure drop formula
10 replies · 4K views
Jack Mc
Hi, Iv got to find the minimum diameter of a pipe if the pressure drops in a system is to be limited to 0.3bar. when delivered through a pipe of equivalent length 160m
I have to use the formula
Pressure Drop = 800lQ^2/Rd^5.31
I believe I have to transpose this to find the min diameter.
compressor delivers 300 l s–1 of free air into a pipe at a pressure of 6 bar gauge.
Using the pressure drop formula: pressure drop = 800lQ2 Rd 5.31
calculate the minimum diameter of pipe if the pressure drop in a system is to be limited to 0.3 bar when is delivered through a pipe of equivalent length 160 m .
d^5.31=800lQ^2/R
Ok so far then take the 5.31th root of both sides.
If your calculator can't do that perhaps logarithms will help..
log(mn) = n * log(m)
Actually I see you forgot to put the pressure drop on the right hand side. If ΔP is the pressure drop it should read..
d5.31=800lQ2/RΔP
d5.31=800lQ2/RΔP
I see thank you. Ill give this a go.
d^5.31=800x160x300^2/6.94x0.3
= d^5.31 = 55.331412.1
Is this the right lines?
Looks right to me although I don't have my calculator to hand.
I get..
d5.31 = 800x160x300^2/6.94x0.3 = 5.5 * 106
then
5.31*log(d) = Log(5.5 * 106)
so
d = 10(Log(5.5 * 106)/5.31)
= 68m
which is very large for a pipe!
Where did the equation come from?
Is the value of R correct?
Should the pressure drop be in bar or some other units?
I got R by...
R=p2/p1
R=6+1.01/1.01
R=6.94
Should the flow rate Q be in L/s or m3/s ?
l = the equivalent length of pipe in metres
Q = the flow through the pipe in ℓs−1 free air
R = p2/p1 = the ratio of compression at the start of the pipe
d = the internal diameter of the pipe in mm
Ah OK 68mm makes more sense than meters.
