Need Help With Guass Laws and Amperes Law
The discussion revolves around applying Gauss's Law and Ampere's Law to analyze electric and magnetic fields in the context of a point charge and a spherical conductor. The original poster presents a series of questions related to the electric field in different regions surrounding a point charge and a spherical conductor, as well as the magnetic field generated by two different configurations of current-carrying cables.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Gauss's Law to determine the electric field in various regions surrounding the point charge and the spherical conductor. There are attempts to clarify the charge distribution and its implications for the electric field in different regions.
  • Questions arise regarding the total charge within specific regions and how it affects the electric field, particularly in regions I, II, and III.
  • There is exploration of the magnetic field generated by two designs of current-carrying cables, with participants questioning the implications of current direction on the magnetic field.
The discussion is ongoing, with participants actively engaging in clarifying concepts and reasoning through the problems. Some guidance has been provided regarding the charge distribution and the implications for the electric field in different regions, but there is still uncertainty and a lack of consensus on certain aspects, particularly regarding the charge within specific regions and the magnetic field calculations.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can receive. There is an emphasis on understanding the underlying principles rather than simply obtaining answers.
AdiV
Hi, I am really stuck with these problems, is it possible you guys can help me out, by guiding me along this problem, I wil write the entire thing out, but would appreciate it if you guys help me step by step so that I can understand it, since I am having a VERY hard time with these problems.
A point charge (+q) is located at the origin. A spherical conductor of inner radius "a" and outer radius "b" surrounds this point charge with its center at the origin. A total charge of =2q lies on this spherical conductor.
{I put the diagram as an attachment}
a) Find the magnitude of the electric field in region I, at a distance r<a away from the origin. Label on the diagram some E field line within this region, if necessary. [Hint: Use Gauss Laws]
b) Find the magnitude of the electric field in region II, at a distance r>1 (but <b), from the origin. Again label on the diagram some E fields if necessary.
c) Find the magnitude of the electric field in region III, at a distance r>b from the origin. Again label on the diagram E field lines if necesary.
Consider 2 different designs for a printer cable. Design 1 has 4 cables each carrying a current I into the page. Design 2 has 4 cables all carrying current magnitude I but two have the current in one direction and two have in the opposite direction.
d) Find the magnetic field at a distance r. (in the plane which is perpendicular to the wires), away from cable 1 by using Ampere's Law.
e) Find the magnetic field a distance r away from cable 2 by using AMpere's LAw.
f) Which design is better, why?
Gauss Law;
[tex]\Sigma[/tex] Eperp * delta A = Qenclosed / [tex]\epsilon[/tex]0
Ampere's Law;
[tex]\Sigma[/tex] Bparallel * delta l = [tex]\mu[/tex]0 * Ienclosed
Again, thank you for the help here.
Ok, I 've been working on it and well, I got to this point, but am not too sure.
a) sigma E perpendicular delta A = E * sigma delta A = E(4*pi*r^2) = Q / epsilon
So wouldn't the charge in section I be +q / epsilon?
c) sigma E perpendicular to delta A = E * sigma A = E * (4 pi r^2) = Q / epsilon
so E = 1 / [4 pi r^2] * Q / b
so, doesn't this tell us that the field outside the uniformly charged spherical shell is the same as if all the charge were concentrated at the center as a point charge??
So that would mean that it is -2q?
I am not too sure
The charge contained within that surface is given as +q. So solve for E.
That's correct. (The formula has a typo: You have b instead of epsilon.)
What's the total charge within the Gaussian surface when r > b?
The total charge is + q?
Can we go over this a bit more? I am really feeling lost right now.
To find the total charge within a surface with r > b, just add the charge at the center (+q) to the charge on the conductor. (What's the charge on the conductor?)
The charge on the conductor is -2q, so +q + -2q will be -q so that is the charge in region I?
No, that's the charge within a sphere of radius r > b. Region I is within r < a; the only charge in that region is the center charge of +q.
Note: The regions are for the purpose of defining the field. For finding the charge, use a Gaussian sphere of the appropriate radius, counting all the charge within that radius.
Ohh, ok, I think I understand now, so for region II the charge would be -2q since that is the charge of the conductor
Careful here: What's the field in region II? (Hint: What's the field within a conductor?)
While the total charge on the conductor is -2q, where is that charge located? What's the charge on its inner surface? Its outer surface?
The E field in a conductor is zero right?
Exactly. So part (b) is easy.
Wow, thank you so much!
Just to prove to yourself that you fully understand it, try to answer my other questions in post #9. (Use Gauss's law.)
  • · Replies 26 ·
