Solve (2-i)x + (-3+4i)y = -2+3i
  • Thread starter Thread starter BlackIP
The discussion focuses on solving complex number equations and matrix problems in preparation for an upcoming final exam. The user seeks assistance with specific math problems, including finding complex numbers and solving matrix equations. Responses emphasize the importance of understanding the concepts rather than simply receiving solutions, urging the user to engage with the material. There is a strong suggestion that the user should have prior knowledge and practice with these topics before the exam. Overall, the conversation highlights the need for self-learning and comprehension in mathematics.
BlackIP
Hi..
i hope i won't be boring but ...
i had some probs this year and i couldn't go to lessions,, so now I'm having a lot of troubles with math...
At 15 january i have my final exam so i had to learn almost 4 book to pass it...
I hope that u will help me to solve some math probs...
(Sorry for my bad english)
(when i underline a number or something.. i mean that it is conjugated)
Here are some of them:
1). we have the complex number z = 1 + 2i. We have to find the complex number
w the way that finally we will have these :
Re{w/z} = 2 and Im{z*w} = 2
2). Solve the equation:
__________________________________________________________________________
3). Here we have to do With Matrix(matrices)...
hope u'll understand the way i wrote them...
We have to find x, y ,u and v so we will have:
/ x-----y+1 \----/ 3 --- x-2 \ -- / y ---- 0 \ -- / 7 --- -3 \
l----------- l - 2 l ---------- l = l ---------- l - l ---------- l
\ 0-----u+4 /----\ u --- v+2 / -- \ -v ---- 2 / - \ 4 ----- 9 /
4). Depending to a parameter, find the matrices rank:
----/ 1 1 1 1 \
A = l 2 a -1 1 l
----\ a 4 0 2 /
----/ 1 7 17 3 \
----l 2 2 a 3 l
B = l 3 1 1 a l
----\ 0 a 10 1 /
----/ 1 -2 3 2 a \
C = l 2 -a 5 -1 7 l
----\ 1 -2 1 -8 2 /
you'll help me a lot if u solve me the probs...
Bye...
Mathematics news on Phys.org
BlackIP said:
Hi..
You have to learn "almost 4 books" now? When did you learn you would have to pass a final exam?
Your English is excellent. I am just concerned that you don't seem to have even tried!
If z= 1+ 2i and w= x+ iy, then \overline{z}= 1- 2i and \overline{w}= x- iy. So w/\overline{z}= (x+ iy)/(1- 2i)= (x+iy)(1+2i)/((1-2i)(1+2i)= (x-y)/5+ (2x+1)i/5. Set the real part of that equal to 2. That gives you one equation for x and y. Do the same with Im(z\overline{w})= 2 to get a second equation.
All right, what have you DONE? Are we to assume that x and y are real numbers? If not there are an infinite number of solutions. You certainly should know that (2- i)x= 2x- ix and (-3+ 4i)y= -3y+ 4yi. That is exactly the same as (2x-3y)+ (-x+ 4y)i= -2+ 3i. If x and y are real numbers, then 2x- 3y= -2 and -x+ 4y= 3.
Do it! Go ahead and multiply the the matrices on each side and set corresponding terms equal. That will give you 4 equations for x, y, u, and v.
----/ 1 1 1 1 \
A = l 2 a -1 1 l
----\ a 4 0 2 /
----/ 1 7 17 3 \
----l 2 2 a 3 l
B = l 3 1 1 a l
----\ 0 a 10 1 /
----/ 1 -2 3 2 a \
C = l 2 -a 5 -1 7 l
----\ 1 -2 1 -8 2 /
Bye...
No, it would not help you one bit for someone else to solve the problems! YOU need to learn to solve them and, all kidding aside, by the time you are taking the final exam, you should already have seen many examples, as well as having solved many of them before. What is the DEFINITION of "rank of a matrix"? Do you know how to find the rank of a matrix by "row reducing" it? Do you know how to "row reduce" a matrix?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
