Need replacement advise for KA3525A IC
  • Thread starter Thread starter HomeExperiement
    Advise Ic
The KA3525A IC, a common SMPS controller in a 16-pin DIP package, can be replaced with the SG3525A without issues, as both share the same pin-out, internal block diagram, and reference voltage. The KH52AD marking likely indicates the manufacturing plant and date code, not affecting compatibility. While the SG3525A may have a longer feature list and is better documented, both ICs are functionally equivalent. It is advisable to compare data sheets for confirmation, but using the SG3525A as a replacement is a safe choice.
  • Understanding of SMPS (Switched-Mode Power Supply) controller ICs
  • Familiarity with IC datasheets and specifications
  • Knowledge of electronic component identification and compatibility
  • Basic electronics knowledge, particularly regarding pin configurations
  • Compare the datasheets for KA3525A and SG3525A to confirm specifications
  • Research the history and applications of SMPS controller ICs
  • Explore alternative ICs for SMPS applications and their compatibility
  • Learn about the manufacturing processes and differences in IC production
Electronics engineers, hobbyists working on power supply designs, and anyone involved in replacing or selecting SMPS controller ICs.
HomeExperiement
Hi!
I need to replace KA3525A IC because I damaged mine with shorted potentiometer. I have question: I also has KH52AD marking on it. Is this also important? I can find KA3525A from aliexpress but KH52AD doesn't seem to show this unit. And when I search for KA3525A, also SG3525A seems to show up in search results quite often. Can they both be used interchangeably is it important that it is KA3525A (like is one just newer model than other or are the 2 different things)?
The KA3525A is a common SMPS controller IC in a 16 pin DIP.
KH52AD may be a manufacturing plant and date code.
The SG3525A has the same pin-out, internal block diagram and reference voltage, so I expect it is a direct replacement.
Ok, tnx. I also noticed that SG3525A is better documented. What do you exactly mean by direct replacement?
Also, which one should I get? SG3525A seemed to have a bit longer feature list so it looks like newer but I am not 100% sure. In other words replacing KA3525A with SG3525A should be fine?
The 3525A is an very common (and old) SMPS control IC. The prefix letters usually just refer to the manufacturer. They are very likely to be compatible, certainly in pin-out and function. Unfortunately, the only way you'll know for sure is to compare the data sheets. Assuming no one's life depends on it, I would just replace it with SG3525A.
BTW the SG stands for Silicon General, the original company (long gone, now part of TI) that originally designed this IC in the early 1980's. This is the most common part number for this IC amongst generic manufacturers.
The masks used to make the silicon chip may be different from different manufacturers, but the specifications will be equivalent to, or better than, the original product. Two manufacturers may merge, or may agree to share some masks to become a second source for an identical product.
The “quantity of specifications” will be reduced as more manufacturers begin to manufacture direct equivalents. The best data sheets and application notes are usually from the original manufacturer, since it was in their interest to help engineers introduce the new product.
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 20 ·
