Need to derive a formula for the number of red giants
The discussion revolves around deriving a formula for the number of red giants in the galaxy, focusing on the relationship between apparent magnitude and star density. Participants explore the implications of density distributions and the geometry of the galaxy in relation to observations.
  • Participants discuss a hypothesis relating the number of red giants to the density of stars and volume in a solid angle. Questions arise about expressing the formula in terms of ΔN/Δm and the necessity of integrating the density function. There is also confusion regarding the implications of the density distribution and the meaning of certain variables.
Participants are actively engaging with the problem, raising questions about assumptions and the dimensional consistency of equations. Some guidance has been offered regarding the interpretation of variables and the need for clarity in the equations being used. Multiple interpretations of the problem setup are being explored.
There are assumptions about the observer's position and the density of stars in relation to the galactic center. The discussion includes constraints related to the apparent magnitude and the use of Taylor series as a hint, though its application remains unclear.
Rageuke
Give an expression for the number of these red giants that can be observed with a given apparent
brightness 𝑚 can be observed within a solid angle Ω.
Express this as ΔN/Δ𝑚 as a function of 𝑚. Assume that this type of red giant represents a certain fraction 𝑓 of the total star population. Further assume also that for this calculation there is no
extinction of the interstellar medium. (Hint: use the given Taylor series that is valid when 𝑥 ≪ 1).
Taylorseries: log(1 + 𝑥) = 1/ln(10)*( 𝑥 − 𝑥^2/2 + 𝑥^3/3 − 𝑥^4/4 + ⋯ )
Assume that the density distribution of stars in the Galaxy can be represented by the following exponential function:
𝑛(𝑟) = 𝑛0*𝑒^−((𝑟−𝑅0)-(𝑅𝑑))
Herein:
𝑟 represents the distance from the center of the Galaxy,
𝑅0 the distance from the Sun to the center of the Galaxy,
𝑅𝑑 the radius of the disk of the Galaxy,
𝑛0 is the density of stars in the vicinity of the Sun.
All distances in the above model are given in 𝑘𝑝𝑐.
An astronomer observes a certain type of red giants in the center of our Galaxy that can be used as standard candles with a constant absolute brightness of 𝑀 = -0.2.
My hypothesis:
The number of red giants is equal to the number of stars times the given fraction f.
The number of stars in a solid angle omega, is given by the density distribution of stars in the Galaxy times the volume of the observed solid angle:
#RG = f*n(r)*V
where V = (d^3*omega)/3.
I assume the maxium distance at which a telescope can see red giants with a given apparent magnitude m is equal to distance d mentionned in the equation above, which can also be calculated with the following formula (relating the apparent magnitude to the absolute magnitude):
M = m + 5 - 5*log(d)
where the base of log is 10
which gives
d = 10^((M-m-5)/(-5))
If you substitute everything, you become an expression with the only variable being the apparent magnitude...
My questions are:
The expression I computed is not expressed as ΔN/Δ𝑚, what could I change to my formul to achieve this?
Shouldn't I use an integral to integrate n(r) to the volume V, to determine the number of stars?
What does the expression ΔN/Δ𝑚 stand for? The number of red giants with a given apparent magnitude m?
It is said I must use the given Taylorseries, I don't know where or when...
Thx in advance for your help! :D
Herein:
I do not understand that. What has the density of stars at distance r from galactic centre to do with the Sun's distance from it?
Also, to be asking about some arbitrary solid angle, I assume d is somewhat less than the thickness of the galactic disc.
Well, they use the density of the stars near the Sun and its distance from the centre of the galaxy as an estimate, you could say a standard, for the density in the rest of the Milkyway. As you go further and further from the centre, the density decreases.
Doh! Yes, I see how that works now.
You didn't answer my second question, so I'll stick with my assumption .
If m is a continuous variable, there are, in principle, no stars with apparent magnitude exactly m. The number ##\Delta N## with apparent magnitude between ##m## and ##m+\Delta m## is a function of m.
To put it another way, if ##N(m)## is the number with apparent magnitude less than or equal to m then you are to find ##\frac{dN}{dm}##.
Please post the expression you got.
Hey, thanks a lot!! I'll post the equation I found once I get home!
The equation I found: dN/dm = f*n(r)*omega*r^2*ln(10)*10^((-M+m+5)/5)
It's a simple and elegant equation, and everything seems to make sense, except the part where I didn't use the given Taylor series, but it isn't explicitly said that I must use it, it's just a hint... (idk why I'm promoting my equation so much btw, it's like I'm making an ad of it)
Wait, there's still a problem with that equation. First, it makes no sense dimensionally: the exponent should be dimensionless. Secondly, substituting ##r=R_0## should give ##n(R_0)=n_0##. So the subtraction of "Rd" should be a division? I'll assume so.
The difficulty I have with this problem is that no direction is specified for the viewed angle. That means we should take the density as constant, no? Otherwise we would need to use a higher density when looking towards galactic centre than when looking away.
So we can take the density as just ##n_0##, and the number of red giants within the view is ##Vfn_0##.
The remaining work is to figure out the distribution according to apparent magnitude.
In your equation in post #6, I think there is some confusion over the meaning of r.
It is not specified wether we are looking from our solar system or any random point in our Milky Way, I don't think you can just substitute r with r0...
First, I'm pretty certain it means an observer on Earth, or it would have said. Secondly, that does not fix the problem with your equation. All it means is that the r in ##n(r)## in your equation stands for ##r_{observer}##, but what is the other r?
I stand by what I wrote in post #7.
Fwiw, I get ##dN/dm=n_0f\Omega \frac 15\ln(10)10^{\frac 35(m+5-M)}##.
  • · Replies 25 ·
