Need to find Green Function to solve ODE
romeo6
Hi,
I have a basic ODE:
y''(x)+\frac{1}{4}y'(x)=f(x)
on 0<x<L
With Boundary conditions:
y(0)=y(L)=0
For which I would like to construct a Green Function.
Rather than just plain ask for help, I'll show you what I've been thinking and maybe someone wiser can help/correct me:
We must solve:
G&#039;&#039;(x,x&#039;)+\frac{1}{4}G&#039;(x,x&#039;&#039;)=\delta(x-x&#039;)
Since G vanishes at the boundaries we can expand as a Fourier sine series:
G(x,x&#039;)=\sum_{n=1}^\infty \gamma_n sin\frac{n\pi x}{L}
and:
\delta(x-x&#039;)=\sum_{n=1}^\infty A_n(x&#039;)sin\frac{n\pi x}{L}
Integrating the delta function I get:
A_n(x&#039;)=\frac{2}{L}sin\frac{n\pi x}{L}
I take the first and second derivative of the equation for G
and plug everything into the differential equation for G:
\sum_{n=1}^\infty \gamma_n (\frac{-n^2 \pi^2}{L^2})sin\frac{n\pi x}{L}+\frac{1}{4} \sum_{n=1}^\infty \gamma_n (\frac{n \pi}{L})cos\frac{n\pi x}{L}=\sum_{n=1}^\infty \frac{2}{L}sin\frac{n\pi x&#039;}{L}sin\frac{n\pi x}{L}
Now I am not sure what to do from here to get the required Green function...can someone guide me please?
:confused:
It's not clear to me why you would use Fourier series. For all x except x', the Green's function satisfies G&quot;+ \frac{1}{4}G&#039;= 0 which has general solution
G(x)= A+ Be^{\frac{x}{4}}
The Green's function must be of the form
G(x, x&#039;)= \left{\begin{array}{c}A+ Be^{\frac{x}{4}} if 0\le x\le x&#039; \\C+ De^{\frac{x}{4}} if x&#039;\le x\le L\end{array}
A, B, C, D depend on x' and are chosen so that the boundary values are satisfied, the two "pieces" have the same value when x= x', and the difference in the derivative when x= x' (left side minus right) is 1: 4 conditions to determine 4 numbers.
Ok, let me try and from some equations from the conditions:
Condition 1.
G(0,x&#039;)=0=A+Be^0
so A=-B
Conditon 2.
G(L,x&#039;)=0=C+De^{L/4}
soC=-De^{L/4}
Conditon 3:
Be^{x&#039;/4}=De^{1/4(x&#039;-L)}
Condition 4.
\frac{Bx&#039;(x-L)}{x-L}+B=1
Does this look about right??
Thanks!
If, by "condition 1", "condition 2", etc. you mean
"A, B, C, D depend on x' and are chosen so that the boundary values are satisfied, the two "pieces" have the same value when x= x', and the difference in the derivative when x= x' (left side minus right) is 1." that I mentioned before, then your equations for "condition 1" and "condition 2" are correct.
For the third one, having the same value when x= x',
A+ Be^{\frac{x&#039;}{4}}= C+ De^{\frac{x&#039;}{4}}
For the fourth, that the difference in left and right derivatives at x= x' be 1,
\frac{B}{4}e^{{x&#039;}{4}}- \frac{D}{4}e^{{x&#039;}{4}}= 1
Thanks!
Yes, that's exactly what I meant by 4 conditions, but I was just borrowing your phrase '4 conditions to determine 4 numbers', so if I have used the phrase incorrectly I apologize.
I'll keep working on this.
In the last condition is that supposed to be 4e or is it a typo and supposed to be e/4?
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
