What would GRT look like if negative masses existed?
  • Context: Graduate
  • Thread starter Thread starter exmarine
    Negative
The discussion explores the implications of negative masses within the framework of General Relativity (GRT), particularly how such a concept might alter the Schwarzschild metric and the nature of gravitational interactions. Participants also consider the application of GRT mathematics to electrodynamics, where forces can be repulsive, contrasting it with gravitational attraction.
  • Some participants question the validity of discussing negative masses in GRT, suggesting it leads to speculative scenarios that may not align with established physics.
  • Others propose that the mathematical framework of GRT could be adapted to explore scenarios where masses repel each other, although this is met with skepticism regarding its feasibility.
  • A participant notes that mass does not directly enter GRT, complicating the discussion of negative mass and suggesting that the question may be rephrased in terms of energy conditions.
  • Some argue that negative energy and negative mass are distinct concepts, with negative mass implying a repulsive gravitational charge, while negative energy relates to energy condition violations.
  • There is a suggestion to consider exotic matter and its potential implications for spacetime and gravity, though its relationship to repulsive gravity remains unclear.
  • A participant expresses a desire for a more thorough exploration of these ideas to aid understanding, proposing that flipping the signs in the equations could yield insights into how gravity might behave differently with negative mass.
Participants do not reach a consensus on the implications of negative mass in GRT. Multiple competing views exist regarding the feasibility and implications of such a concept, as well as the appropriateness of applying GRT to electrodynamics.
The discussion highlights limitations in the current understanding of mass within GRT and the challenges of applying its formalism to other forces like electromagnetism. There are unresolved questions regarding the definitions and implications of negative mass and energy.
exmarine
What would GRT look like if negative masses existed? What would be the "Schwarzschild" metric, etc.?
This question amounts to asking "if the laws of physics didn't apply, what would the laws of physics say about <fill in anything you like>?"
Search the forums for "negative mass" for many previous threads on various aspects of this idea.
And as a follow-on to Jonathan's suggestion, there is always a list at the bottom of each thread of 5 threads that have similar titles and I've usually found those to be a good place to start.
Yes, I had searched through some of those. But my interest is in why we don’t use the exquisite math in GRT to describe “spacetime(s)” in electrodynamics, where there is repulsion in addition to attraction? So I wondered if anyone knew how “gravity” would look if masses repelled each other instead of attracting.
You're asking two different questions here.
We don't use spacetime curvature and its associated formalism to describe electromagnetism because that approach only works for forces whose strength is exactly proportional to the mass the force is acting on (this is one way of thinking about the equivalence principle). Electromagnetism is not such a force; two objects of the same mass can have different charges and hence experience different forces and accelerations. Gravity will never you give different accelerations for different objects at the same place.
As Phinds has said above, there is no way of using science to answer this question. It's like asking which animal would be the natural prey of elephants if elephants were carnivorous - it's an interesting question, but you should ask it of a science fiction writer not a biologist.
We can pursue the first question here, but the second is out of scope for PhysicsForums.
First, mass doesn't enter into GR directly. It enters in only as the norm of the energy-momentum four-vector, and so the original question boils down to "how would GR look if lengths were negative?" This can't be answered, as lengths aren't negative.
The next question, of using GR math for E&M, is answerable two ways. One is that the GR formalism is a) overkill and b) inappropriate - inappropriate because E&M is a vector theory and GR is a tensor theory. The other is that there is a section in MTW where they cast E&M in a way where it fits better into GR, but it's still rather unwieldly.
atyy said:
To phrase this question within general relativity, one would probably look at the energy conditions. http://en.wikipedia.org/wiki/Energy_condition
Violations of the most common energy conditions are discussed in http://arxiv.org/abs/gr-qc/0001099.
Negative energy and negative mass are two different things. The latter implies (as stated by the OP) a repulsive 'gravitational charge' , which is not at all the same as negative energy or energy condition violations. The latter lead to hypothetical scenarios where spacelike transport is possible (but not repulsive gravity).
Well, I don't know if negative mass is defined in GR, since mass itself is not really defined, so I was just suggesting a way to make it well-defined. But if one wants to go more in the spirit of "repulsive gravity", how about a cosmological constant for the accelerating expansion, or exotic matter for wormholes?
Exotic matter is what I was referring to. It violates energy conditions, may lead to worm holes or several other ways to have effectively spacelike transport, and can be considered negative energy but not mass. I'm not aware that it leads to repulsive gravity.
Cosmological constant is interesting but constant - not something you could get a lump of.
I've never seen any speculative proposal within the math of GR that has a two bodies responding oppositely to the influence of a third (without bringing in other charges). Exotic matter might respond differently but not in opposite sense compared to normal matter.
How about proposals where the cosmological constant comes from some form of matter, say like quintessence?
If you have any reference to such application, it would be interesting. Given the ocean of papers published on speculative approaches to FTL using exotic matter, I would think that if someone had conceived of a speculative formulation where quintessence could lead to an anti-gravity device (for example), they would have published a paper about it.
Plug exotic matter into Raychaudhuri's equation.
I don’t understand why you guys (some of you at least) brush the question aside. Here’s how a serious answer might help a self-taught beginner like me, and maybe others, understand the theory better. I’ve worked my way all the way through the math but don’t understand the big picture very well yet – obviously. I don’t know exactly where I told the math that Galileo’s two objects fell DOWN rather than UP. Working backwards, it seems that the signs of the Christoffel symbols would have to at least flip in the geodesic equations so that, for example, a photon grazing the sun would curve away from it rather than toward it. Also it seems that the potential energy would flip sign. It would approach infinity as the radius goes to zero, and approach zero at r goes to infinity. So change (-r_s/r) to (+r_s/r) I suppose? When I get a block of time, I’ll study that and see what happens. So I’ll work it out myself, thanks anyway.
PS. Yes I know that trying to analyze electrodynamics with this math would be complicated, maybe even impossible. But again it would facilitate understanding for me.
I think the closest answer is exotic matter discussed in the last several posts. If you express the stress energy tensor (the source term for gravity in GR) in a local orthogonal frame at some event, the 00 term is normally positive and corresponds to total energy density. You can, within the math, make it negative instead. This is exotic matter. The implication of George Jones comment is that in addition to FTL effects I'm familiar with, you can get some repulsive gravity behavior as well.
However, in contrast to EM, there is no analog of charge (a conserved scalar quantity) that is a source of gravity, so there is no way within the math to simply reverse gravitational attraction by charge reversal. Mass itself is not not fundamental in GR, it cannot even be defined in the general case (including, in realistic cosmologies). This is the sense behind the response: you can't express this idea in GR.
To get repulsion you would have to flip the sign of the gradient of the gravitational time dilation factor, which is the square root of first term in the metric:
http://en.wikipedia.org/wiki/Schwarzschild_metric#The_Schwarzschild_metric
But I'm not sure what that implies for the spatial metric components under the given boundary conditions, and if there can be a valid metric at all like this.
By Birkhoff, it would be impossible for spherical, non-rotating, body to produce such a metric, since the solution is unique (for cosmological constant zero). With a cosmological constant, you could get repulsive effects, but they would not appear to originate with the central body.
I know Bondi pubished some papers on the topic of negative mass in GR, for instance
Negative Mass in General Relativity Rev. Mod. Phys. 29, 423 – Published 1 July 1957
I think I've seen Bondi's paper at one time, but it doesn't seem to be publically available anymore. I believe that considering the topic eventually led him to create the so-called Bondi mass.
Google finds some other remarks by Bonnor as well. General Relativity and Gravitation, Volume 21, Issue 11 , pp 1143-1157
There appears to be some concern about run-away motion if positive and negative masses coexist from what I can gather from what fragments of the papers are on the WWW. I believe that you get very bad behavior if you allow a gas consisting of negative mass particles to interact with a gas made of positive mass particles, though I don't recall the source of the argument. The argument ias I recall it s that that thermodynamically, the negative temperature negative-mass-particle gas would gain negative energy and the positive-mass-particle gas would gain positive energy. Thermo isn't my best subject, but it does seem to me to maximize the total number of states - the positive mass gas has positive kinetic energy and a positive temperature, the negative-mass gas has negative kinetic energy and a negative temperature, and the negative temperature is "hotter" than the positive temperature. (See for instance the wiki article on negative temperature). Thus you get the run-away effect where the entropy is maximized by a high positive energy and positive temperature for the positive mass gas, contributing a positive number of states / entropy S = Q/T, and you get an equal contribution from the negative Q and the negative T from the negative mass gas.Anyway, I believe there is a fair amount in the literature on negative mass, but it's all rather old. and my recollection is that the main concerns are rampant instability if you have negative mass interacting with positive mass.
Do you recall how they define negative mass? Is it just negative 00 component of SET (which most authors would call exotic matter), or do they derive altered field equations (thus more like alternate GR rather than negative mass in GR)? The one page of Bonnor that I can see without pay from your link does not specify, but it seems the assumptions in the abstract would lead to different field equations (thus not what I would call GR).
Pay attention to George Jone's remark in post #14 if you are interested in negative mass in the sense of repulsive gravity. For electromagnetism, off the top of my head, something close to what you are thinking in which some parts of electromagentism are reformulated geometrically is Kaluza-Klein theory http://ncatlab.org/nlab/show/Kaluza-Klein+mechanism. A possible geometric origin of the Lorentz force law for electric charge is explained in https://dl.dropboxusercontent.com/u/56141091/Lorentz.pdf . However, in George Jones's case, I believe the exotic matter he is thinking about actively generates repulsive gravity. In the electromagentic Kaluza-Klein case, the charge is passive and only feels the electromagnetic field, and doesn't generate it. I don't know if the theory can be extended to include active electric charge.
A more traditional way to understand why gravity is only attractive, while electromagentism can be both is by understanding gravity as a tensor field, and electromagentism as a vector field. If Peter Donis is reading this, he can fill you in on the details. I'll look it up later if he or someone else more knowledgeable than me doesn't join in.
Here is a recent paper on this which states that while for asymptotically flat spacetimes, negative mass must be exotic matter that violates SR locally ( classically - the dominant energy condition), If one goes to de Sitter spacetime, you can have a notion of negative mass that is not exotic in that it does not violate the dominant energy condition.
http://arxiv.org/abs/1407.1457
My vague recollection is that Bondi just considered the Schwarzschild metric with a negative mass parameter m. So it would be a vacuum solution, would satisfy the standard GR field equations, and interestingly enough would have no event horizon as a consequence of the change in sign for m.
I believe this idea was motivational in Bondi developing the Bondi mass, and I think Bondi wound up saying that one couldn't start with a positive Bondi mass and wind up with a negative one, but I might be remembering wrong, alas.
Sorry I don't recall more, I'm not really that I'm remembering right, either. But if the OP is interested in negative mass, it'd be a paper worth looking at, if he can manage to find it.
This paper does not address the motion of such a bubble. However, my recollection of the arguments where motion of bodies is derived from the field equations themselves (Ehlers; Wald, Gralla; etc.), is that that these are quasi-local arguments, and need not rely on any global assumptions like asymptotic flatness. They show that a body satisfying the dominant energy condition will move approximately on a timelike geodesic if it is not subject to force (e.g. EM force). If I am right on this, then it suggests that a negative mass object that is not exotic would respond to a massive body of (of either positive or negative mass) the same way a positive mass body does. This gets at how tricky it is to introduce something like two charges in EM into GR for mass.
The upshot is that my post #16 remains a fair summary of that issues for negative mass in GR. Note, in particular, that the two most general definitions of mass in GR (ADM mass and Bondi mass) do not even apply in de Sitter spacetime. Thus, the situation where we can get a non-exotic body that produces a field like Schwarzschild with a negative mass parameter, is a situation where mass is undefined in general, and that parameter we label M cannot clearly be interpreted as mass.
In some limited sense, negative mass already exists, because negative energy exists. More specifically, gravitational potenital energy is negative. Two masses close to each other have less total mass than the sum for their masses independently, or if they were far from each other... and yes, I realize how absurd and hard to parse is that sentence.
In fact, two equal masses that were somehow put at rest to each other at a distance of about half their schwarzschild radius would exactly cancel out their mass with their negative potential energy and would end up having a mass 0... and if you could take out some energy from them and put them even closer together, you would have negative mass. Of course, the whole black hole formation thing kinda gets in the way, I know...
georgir said:
In some limited sense, negative mass already exists, because negative energy exists. More specifically, gravitational potential energy is negative. Two masses close to each other have less total mass than the sum for their masses independently, or if they were far from each other
If I start with two objects far apart and move them closer together, the total mass/energy of the system does not change - unless some energy is radiated away in the process and I accidentally forget to count it. Calling that "negative energy", even in a limited sense, is like saying that the number of cookies on the plate going from twelve to eleven when I eat one demonstrates the existence of negative cookies.
If you let them fall toward each other, accumulating relative velocity, then you are right. But if you "move them closer together" with an external influence, leaving their relative velocity unchanged (or 0), you are taking energy away from their system - not exactly "radiated away" but close enough, I guess. And yes, once they get closer than schwarzschild radius, you can not practically continue to do it, so yes, my example is not completely physical. But I tried to say that in my first post as well.
Edit: And it is not as completely meaningless as the negative cookies example, because of superposition of forces. To describe the resulting gravity you will have to use the two normal masses as well as a negative mass (or rather energy density)
It's true that in Newtonian gravity one can have a self-gravitating system with arbitrarily negative energy due to gravitational binding energy but this is not so in GR; there is a theorem that says the mass (ADM energy) of an asymptotically flat curved space-time must necessarily be positive if the dominant energy condition holds, and it is known as the Positive Mass Theorem. The assumption of the dominant energy condition basically means that local energy densities of matter distributions must be positive. For such systems one can think of the physical reason behind this as being: if one tries to compress a self-gravitating isolated system thereby attempting to make arbitrarily negative the gravitational binding energy one will eventually form a black hole, which has positive ADM energy. A similar theorem can be proven for Bondi energy (ADM energy is taken at spatial infinity whereas Bondi energy is taken at null infinity and includes radiation).
I just had a scary thought... wouldn't this negative potential energy (or said in another way, our taking away of the kinetic energy of the system as the two objects fall toward each other) also cause the schwarzschild radius of the system to shrink, so we can never actually reach it?
Edit: Nevermind, I guess WannabeNewton's answer puts that to rest... now all I have to do it understand it.
I believe it is ADM energy that includes radiation and Bondi energy that excludes it, so the Bondi energy of a binary system decreases while the total ADM energy remains constant.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 56 ·
