Negative pressure in house after winterizing
  • Thread starter Thread starter Greg Bernhardt
    Negative Pressure
86 replies · 11K views · last reply
OmCheeto said:
Wondering if it's glass covered or open.
Open. In the end by sealing up everything else, it could cause the chimney to back-draft right? I do have carbon monoxide detectors on each floor.
That was my worry. But I have a friend with a natural gas fire place log thingy, and it vents INTO the house. I didn't really look into it until yesterday as to how they work, without killing the occupants:
ventless-fireplaces-what-you-need-know
...These safety devices automatically shut off the fireplace if the carbon monoxide level in the room rises above 25 parts per million, and/or the oxygen level falls below 18%...​
[ref]​
Looking through the manual for your boiler, it appears to have a powered damper(page 13), so I think we can eliminate that as a problem, when it's not in operation.
The instructions also mention, on page 6, that exterior air needs to be supplied.
One of several options mentioned:
Mechanical Air Supply. Provide minimum of 0.35 cfm per Mbh for all appliances located within space.
Additional requirements where exhaust fans installed.
Interlock each appliance to mechanical air supply system to prevent main burner operation when mechanical air supply system not operating.
Unfortunately, I doubt your gas fireplace has such an interlock.
And it also sounds like most of your house is very well sealed.
If I were you, I'd add an intake duct adjacent to the fireplace intake.
Not sure if this is feasible.
If not, you might try leaving the door to the basement open, and see if that stops the attic door, and downstairs window drafts.
btw, did you ever find the model number for your fireplace?
OmCheeto said:
Anyone know how flame angle corresponds to wind speed? I googled it, and couldn't find anything.
I'm not looking for higher powers to answer my question...
I must take strong exception to your assessment of my ability to answer questions... I will, however, offer some gentle guidance.
Consequently, of course, you must independently... determine the relevance . . :-p
It would appear that "candle" is the culprit for summoning wannabe deities.
Looking at the sources in your google search, I've decided flame angle is too complicated, and I'm going to ignore it.
But back to the problem.
@Greg Bernhardt , do you have a gas fired water heater hooked up as shown in your boiler manual(page 13)?
God knows, we need another variable here...
Water heater is vented directly outside through basement wall. I have a humidifier running in the basement but that just cycles inside air right?
I would think so.
So, did we ever determine if you have an outside air source to your basement?
The water heater is going to be drawing air into your house.
So, although it may not be adding to the "stack effect" of your chimney, it's definitely a pertinent variable.
[edit: I think we can ignore the humidifier as a variable in this problem. Not to say that humidity levels aren't a problem, but that's another thread, IMHO.]
... question is how do I shore up these two massive air exchange areas but not create a negative pressure issue, ...
from https://fixhomeenergy.com/2010/11/02/solution-basics-pressure-balancing/
Ideally, the pressure difference between inside and out is near zero, just like it is with an air leaky house. Mechanical ventilation works well only when there is a pressure difference between inside and out. Therefore, it’s unrealistic to expect a tight house be at neutral pressure with respect to outside at all times.
bold by me
But if it was stack effect why would the attic door plastic be pushing inward. Wouldn't it push outward from the warmer inside air?
Maybe. In a perfect stack all the air goes out the top and in the sides. In a house that has a tight enough roof, it might go out the top floor. But it is tough to know.
The air has to be coming from somewhere though, and there are only a few possibilities; fan forced, stack effect and wind are pretty much it.
It is trying to come from the great outdoors. Assuming there is not a continuous wind blowing on those plastic sheets, the question is where is it leaving to create the partial vacuum?
p.s. Incense sticks also create enough smoke to help track the air movement.
Yes, I said the problem backwards.
My bet is on the stack effect. Does it seem more pronounced on sunny days than on overcast days or on cooler nights? That would seem to support the stack effect.
But again wouldn't that make the plastic on the attic door push outwards?
Something else I just thought of was that I have a radon exhaust fan but the pipe goes from the basement floor (sealed) to the outside.
The typical flow in the smokestack effect is inflow at the lower levels and outflow at the higher levels, but there can be other things going on.
Hard to be sure with limited information. The house I am picturing in my mind is like older homes we lived in in the NE, but the actual home in question might be much, much different.
(sealed)
Whole new ball game.
Good deal, I read this before having my coffee: " Negative Pleasure in the Attic". Wow, this Greg is into pretty cool, avant-garde stuff. That one I could try to answer, but I can't help with the negative pressure one, sorry.
From what I can see it takes air from under the house and sends it outside.
Is the following close to an accurate doodle of your house?:
By "under the house", do you mean "basement"?
ps. I think the mentors should all conspire to threaten to resign unless you start using the "Homework template" with these problems... :oldgrumpy:
Problem: The pressure in my living area is less than in the attic and outside. Why is that?
Variables: Boiler, water heater, and radon gas extractor are in the basement. Fireplace is in the living area.
Data:
Chimney cross sectional area is: ?
Chimney height is: ?
Fireplace maximum BTU/hr output is: ?
Fireplace idle BTU/hr output is: 1000
Boiler maximum output is: 125,000 BTU/hr
Radon gas extractor flow rate is: ?
Fan supplying outside air to basement flow rate is: ?​
Not a clue.
I don't know where to begin.
That's pretty good!
The pipe goes into the basement floor and sucks air from under the basement floor
I hope the water heater vent goes clear up to the roof - else taller chimney draft can overwhelm it and suck combustion products in backward.
That's pretty good!
Yay!
I'm going to go out on a limb here, and call this "radon destroyer" device a "non-significant" variable.
My guess as to the "most significant variable" would be: Fireplace maximum BTU/hr output...
This would lead to an inferred minimum opening for your chimney flue damper.
The damper is pinned open about an inch.
..., so long as it was "proper retrofitting." How many cracks in the basement floor?
None, it was sealed with epoxy paint a few years ago
Including all water, sewer, gas line, et cetera, ... "hokay."
Seems that would be sucking air from that floor, and that would also draw air from the attic door, causing the plastic to be sucked into the room.
I'd expect the water heater has a powered vent, that is typical of a through-the-wall exhaust. Probably PVC?
Does the effect vary with wind direction ? Along vs across the ridge-line ?? Or relative to any eave gaps ?? Harking back to something I read long ago on storm resistance, specifically venting 'attic pressure' lest it help remove your roof, I'm thinking 'aerodynamics'...
My opinion: Everything in the house creates heat. People, stove, water boiler, oven, TV, etc. That has to go someplace. So it's found a way out. Chimney, holes for the lights, wall outlets, door jams etc. That creates a current of air that is creating an negative (with relation to outside) vacuum. So the air is trying to come by the windows to equalize the house pressure.I found this out when I put a cooler in the attic. I had an evap cooler in the attic and it did a great job. Problem was it also pushed all the humid air into the house. It took me years to patch all the air gaps and there were hundreds. I've got it pretty close now, but there is a still a slight breeze when the cooler is running. (Enough to push a door closed to the garage if it's slightly ajar. Before I did all the patching and plugging it would slam that same door closed!) Your case is the opposite, but it's still probably the same thing. And as others have said any course of heat that burn something has to pull it's air from someplace. But even if you had them all vented with their own intakes, you, your TV, your stove, etc being in the house will generate heat that is trying to find a way out. Once it does, you create the vacuum you are seeing.
Once you plug all those leaks you'll probably see positive pressure in the house.
HTH
Small update: I found evidence of mice in my basement but couldn't figure out where they were coming in from. Then I crawled under my deck which has very low clearance and saw there is essentially a missing brick in the lower outside wall. Obviously that is how they are getting in and I wonder if that hole was contributing to my pressure issue. I mean literally there is a brick size hole leading into my basement. I never saw it from the inside because there is dry wall down there.
Well spotted ! Was there an old pipe or something before ?
Whatever, at this time of year, expanding foam is your friend...
