Negative rod to uncharged metal ball:
The discussion revolves around the behavior of an uncharged metal ball when a negatively charged rod is brought near it, focusing on concepts of charge distribution and polarization in conductors.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the effects of a negatively charged rod on an uncharged metal ball, questioning the assumptions about contact and charge transfer. There is a discussion about the electric field inside a conductor and the concept of polarization.
Participants are actively engaging with the problem, clarifying misunderstandings about contact between the rod and the ball. Some suggest that the ball becomes polarized due to the presence of the electric field, while others express confusion about the implications of the rod's proximity.
There is a notable emphasis on the distinction between contact and non-contact scenarios, as well as the implications of charge distribution within conductors. Participants are grappling with the definitions and effects of polarization in this context.
sonastylol
[SOLVED] negative rod to uncharged metal ball:
If a negatively charged rod is held near an uncharged metal ball, the metal ball:
1. becomes positively charged.
2. becomes polar.
3. Effect cannot be determined.
4. becomes negatively charged.
5. is unaffected.
I guessed number 4, thinking that if the negative rod touched the neutral ball, the ball would gain electrons ( since its easier to gain and lose electrons - very very difficult and rare for an object to lose or gain protons )
This would make the ball negative but I was wrong... what's the catch here?
The negative rod does not touch the ball though. What do you know about the electric field inside of a conductor?
oh my god. i read it as touched.IT NEVER TOUCHED X_X
there is no change - no contact was ever made.
wait, unaffected is the wrong answer x_x now what am i missing?
wow - yikes... is it not determinable?
The answer is it becomes polarized ; the ball has an effective separation of charge
Yes you could get the answer by knowing that inside the conductor that the electric field must be zero. So when the negative rod goes towards the conductor, then a bunch of positive charges need to go towards the end the rod approaches, and then negative charges must accumulate on the other side. It polarizes.
