Why is a negative spring constant unrealistic in this system?
A negative spring constant is unrealistic because it implies that the spring would produce a force in the direction of the applied force, contradicting Newton's third law. In the given spring system, the lower spring's softness (k2 being small) means it cannot effectively counteract the force applied, leading to an unrealistic scenario where the top springs do not experience any force. The calculations indicate that a force of 5N would excessively extend the lower spring, suggesting that the top springs would not behave as springs under these conditions. Ultimately, the situation described does not align with the physical behavior expected from a spring system, reinforcing that a negative spring constant is not feasible. Understanding these dynamics clarifies why the derived negative value for k1 is not applicable in this context.
user977784078
A spring system consists of two parallel springs on top and a single spring connected to them on the bottom as shown:
http://i.imgur.com/hgMr12U.png
If the system is extended by 7 cm (i.e. x = 0.07m), F = 5N and k2 = 10 N/m, explain why the value of k1 is unrealistic.
F = \frac{2k_1k_2x}{2k_1+k_2}
k_1 = \frac{F k_2}{2k_2x-2F}
[/B]
When I solve for k1 using the given values, I get k1 = -6, but I know that spring constant can't be negative. If spring constant is large and positive, it means the spring is stiff, if it is small, it means the spring is soft, and if it is zero, it means the spring is very soft that it doesn't counteract the force applied to it.
A negative spring constant makes no sense, so what is the correct explanation in this situation?
I have these explanations:
  1. Since k2 is small, the bottom spring is soft, so the top springs don't experience any force since the bottom spring is very soft and counteracts the force applied.
  2. Since k2 is small, the spring is denatured so the top springs aren't affected by the force.
  3. A negative spring constant means that the spring doesn't counteract the force applied to it but instead it produces a force in the direction of the applied force and according to Newton's 3rd law, this is not possible unless an external force acts on the spring.
Am I missing something here?
You try to explain something unrealistic. The question only asks to explain WHY it is unrealistic.
The 5N would lengthen the lower spring alone by 0.5 m already, so if 0.07 m is determined, the other two don't act as springs.
In your explanation 1 you would still measure an extension of at least 0.5 m.
I don't know what a denatured spring is, but if you mean completely deformed to a taut wire, that would mean the extension when a force of 5 N is applied is still >> 0.5 m , so reasoning number 2 doesn't fly either.
Reasoning 3 is more sensible: if the observation is not some stupid error (0.7 m extension instead of 0.07 m, for example...) but a real measurement, the top two contract by 0.43 m when a force of 5N is applied. So they form some kind of mechanism, but definitely not a spring.
Thank you very much for the great answer BvU. I realize now that I can't explain why the value is negative because it is unrealistic but that I can explain why it is unrealistic.
  • · Replies 58 ·
  • · Replies 53 ·
