How Do You Calculate Net Electric Flux Through a Cube?
The net electric flux through a cube with edge length L = 1.07 m can be calculated using the formula Electric Flux = Electric Field * Area. Given the electric fields E1 = 35.1 N/C and E2 = 25.3 N/C, the flux must account for the direction of the fields, assigning positive values to flux leaving the cube and negative values to flux entering. By summing the individual flux contributions from each face, one can determine the net flux, which directly relates to the net charge within the cube according to Gauss' Law.
  • Understanding of electric fields and their directionality
  • Familiarity with the concept of electric flux
  • Knowledge of Gauss' Law
  • Basic proficiency in algebra for summing flux values
  • Study the application of Gauss' Law in various geometries
  • Learn how to calculate electric flux for non-uniform electric fields
  • Explore examples of electric field calculations in three-dimensional shapes
  • Review integration techniques for electric field problems
Students studying electromagnetism, physics educators, and anyone preparing for exams involving electric fields and flux calculations.
Kurtis McIntosh
Assume the magnitude of the electric field on each face of the cube of edge L = 1.07 m in the figure below is uniform and the directions of the fields on each face are as indicated. (Take E1 = 35.1 N/C and E2 = 25.3 N/C.)
A.) Find the net electric flux through the cube.
B.) Find the net charge in the cube.
Electric Flux = Electrical Field * Area
I don't really understand how to solve for the net electric flux in the problem. I thought you would just take the difference in forces for each direction, multiplied by the area, then solve to find the magnitude using the x and y fluxes, but I'm clearly missing something here. I've included a photo of the cube. I've also tried solving for the flux on each individual face and then finding the sum of the fluxes, but that doesn't seem to work either.
Hi Kurtis, Welcome to Physics Forums.
Your Relevant Equation holds the key. The flux through a given area is given by the field strength multiplied by the area (for a uniform field over the area, you need to get fancier and do an integration if the field is not uniform). Note in the diagram that some fields are directed out of the face while others are directed into the face. That is to say, some flux is leaving the cube and some is entering it.
Assign a positive sign to flux leaving the cube and a negative sign to flux entering. Sum them up (algebraically).
If there is a net flux leaving or entering then there must be a charge inside the cube (See Gauss' Law).
  • · Replies 17 ·
9K
