Network function for an opamp circuit
13 replies · 2K views · last reply
Cocoleia
Circuit schematic of an op-amp network: source vs in series with 50 kΩ resistor to ground, feedback 200 kΩ resistor and 1 µF capacitor in parallel to the output vo, with the network function H(ω) = Vo(ω)/Vs(ω) written above.
Handwritten op-amp circuit: source VA feeds the non-inverting input VP, inverting node Vn joins a 200K resistor and a capacitor (-jwC) in feedback to output Vo, with 50K resistor to ground. Below, Vp = Vn = VA and nodal equations in parallel.
Handwritten notes on lined paper: 1/200k = 1/(-jwc) = 1/(-jw(1µ)), with 'solve for w' written at top right, and the boxed result w = 200k/1µ. Below, VA - Vo over 200k = VA - Vo over -j(200k)(1µ), and the question VA = Vo?
I'm really unsure of what to do. I feel like Vs should not be equal to Vo. I am not sure if I have the right idea with the equations that I have written. I am confused because I don't know the value for omega. Can someone help ? Thanks.
Write the node equation for node 1 (figure below) knowing that its potential is equal to that of the source voltage. Be careful with the impedance of the capacitor: What's the difference between the impedance formulas for a capacitor and an inductor?
Circuit schematic of an op-amp feedback network: source vs drives the non-inverting input; node 1 at the inverting input connects to a 200 kΩ resistor and a 1 µF capacitor in parallel to output vo, and to a 50 kΩ resistor to ground.
Edit: By the way, the "network function", or "transfer function" is a function of ω, so it will remain as a variable in your result.
Handwritten-style equation: Vs/50k = (Vs - Vo)/200k + jwc(Vs - Vo).
would this be the node equation, since the current going into the op amp is 0?
You're right that the current going into the op-amp input is zero. But there are a couple of things wrong with your equation. In the third term you shouldn't have voltage in the denominator when all the other terms are divided by an impedance. The first term is written as a current flowing out of the node, so if the other terms are on the other side of the equals sign they must represent currents flowing into the node. That's not what the order of the voltages in the terms suggest.
To avoid errors by making the process automatic, a good approach is to always write a node equation as a sum of terms that sum to zero. That is, place all the terms on one side of the equals sign and a zero on the other. Choose one direction for the assumed current direction for all the terms, either all into the node or all out of the node, then write all the terms with that one assumption. The math will then take care of the details and you don't have to try to figure out ahead of time what the "real" current directions are.
Handwritten-style node equation: 0 = (Vs - Vo)/200k + (jwc)(Vs - Vo) + Vs/50k.
Would this be the node equation then? If I assume that the current is entering the node in all three directions. Since it would be Vs-Vo / (1/jwc) the the jwc comes to multiply on top ?
Actually you've written it as all the currents flowing out of the node (the node is at potential Vs, so Vs - Vo would be for a current flowing from Vs to Vo). Looks good. Plug in the capacitor value and solve for Vo.
Vo=0.2j+5Vs, now can I simply divide them to get the network function ?
That doesn't look right. There should still be ω involved. Can you show more of your work?
Sorry, ignore that it was completely wrong:
Vo=200kwj+5Vs
Vo=200kwj+5Vs
Nope. Show your work.
Much better! You could clear the decimal by multiplying top and bottom by 5:
##V_o = V_s \left( \frac{25 + jω}{5 + jω} \right)##
Now it just remains to form the transfer function H(ω) as described in the problem statement.Edit: Inadvertently wrote ##V_A## instead of ##V_s##. Fixed it.
##V_o = V_A \left( \frac{25 + jω}{5 + jω} \right)##
Ok, I do so by just dividing Vo/Vs. So in the end there is no more term with Vs ?
Right. H is the ratio of the output to the input and is a function of ω.
