Liming Lakes: A Solution for Acidification?
Liming, the process of adding limestone (CaCO3) to acidified lakes, can effectively neutralize lake acidity. A calculation indicates that approximately 610 kg of CaCO3 is required to neutralize a 3.8e9 L lake with a pH of 5.5. However, the discussion reveals that this calculation oversimplifies the process, as it does not account for the solubility of calcium carbonate, water autodissociation, and the buffering effects of carbonic acid. A more comprehensive analysis is necessary to accurately determine the amount of CaCO3 needed for effective neutralization.
  • Understanding of acid-base chemistry and pH levels
  • Knowledge of stoichiometry and molar mass calculations
  • Familiarity with the solubility principles of calcium carbonate
  • Basic concepts of water chemistry, including autodissociation and buffering
  • Research the solubility of calcium carbonate in various pH conditions
  • Study the buffering capacity of carbonic acid and bicarbonate ions
  • Explore advanced stoichiometric calculations for acid-base neutralization
  • Investigate case studies of successful lake liming projects and their methodologies
Environmental scientists, chemists, and ecologists interested in lake restoration and acidification mitigation strategies.
StarChem
TL;DR
Neutralizing acidified lakes
Lakes that have been acidified by acid rain can be neutralized
by liming, the addition of limestone (CaCO3). How much
limestone in kilograms is required to completely neutralize
a 3.8e9 L lake with a pH of 5.5? (question credited to Introductory Chemistry Essentials book)
I calculated it and found that is approximately 610Kg needed of CaCO3 to bring the lake pH to a neutral level.
Is my calculation right 1st :)?
Then if this is right, 610kg of CaCO3 is not that much in a matter of cost or weight to help the bio-life of the lake. I'm wondering if we are applying actually this solution? As far as I know, there is no harm to add CaCO3 to water lakes, water is even drinkable with dissolved CaCO3 ions to some extent.
Cheers
Chemistry news on Phys.org
610 or 601kg?
Not that it is a right answer, but at least let's make sure what we deal with. 601 kg is what I get using highly simplified approach (so simplified, it is actually completely wrong - the only thing that is correct is a stoichiometry).
Yes I used stochiometry and 2 significant figures as the result on the calculator was 608kg.
Perhaps some discrepancy in molar masses used, or you rounded intermediate results.
Trick is, this is incorrect. This is not a simple stoichiometric neutralization. What will happen is that the salt will dissolve and carbonate ions will get protonated, then some will get protonated further into carbonic acid.
To find out how much calcium carbonate needs to be added one should take into account its solubility, water autodissociation and buffering effects of the carbonic acid/hydrogen carbonate ion. Probably further analysis will show of these can be safely ignored - but it is not obvious to tell which ones without doing at least some initial estimates (at pH 7 amount of CO32- is negligible, so Ksp is probably not needed). This is actually quite a nice problem, but IMHO a little bit beyond introductory chemistry.
I have re-done this problem, and indeed your "most simplified" :smile: is more accurate:
I also found this old magazine article about liming lakes:
Cheers!
