New experimental proof of wave-function collapse?
The discussion centers around a recent experiment that claims to demonstrate wave-function collapse, with participants exploring the implications of this claim in the context of quantum mechanics interpretations, particularly regarding non-locality and entanglement. The conversation touches on theoretical interpretations, experimental evidence, and the philosophical implications of quantum mechanics.
  • Some participants argue that the experiment demonstrates non-locality rather than wave-function collapse, suggesting that quantum steering effects do not equate to collapse as defined by Von Neumann's postulates.
  • Others propose that the experiment can be explained through interpretations like Bohmian mechanics, which involve non-locality but do not necessitate collapse.
  • There is a suggestion that the paper's authors may be aware of the non-collapse interpretation but present their findings in a way that attracts more attention, particularly in high-impact journals.
  • Some participants express skepticism about the necessity of collapse in explaining entanglement, arguing that long-range correlations can be accounted for without invoking collapse.
  • A later reply questions whether the minimal interpretation without collapse can adequately explain measurements considered in non-simultaneous frames.
  • There is a discussion about the existence of a Bohmian interpretation of the standard model, with some participants noting that it is not widely accepted or explicitly formulated due to aesthetic concerns in theoretical physics.
Participants generally disagree on the interpretation of the experiment's results, particularly regarding the necessity and implications of wave-function collapse. Multiple competing views remain, with no consensus reached on the interpretation of the findings.
Participants note that the interpretations of quantum mechanics vary widely, with some interpretations explicitly incorporating collapse while others do not. The discussion highlights the complexities and nuances involved in interpreting experimental results in quantum mechanics.
  • #91
What is unclear concerning quantum statistics? The H theorem is most naturally derived from detailed balance which follows from the unitarity of the S matrix, i.e., the (generalized) optical theorem, which is at the heart of quantum-many body theory. Ironically, it's much harder to do classical than quantum statistical physics. Even if you try to do everything in terms of classical theory, you need to introduce quantum ideas to make everything clear. Although thermodynamics and statistical physics survived the quantum revolution best, many "clouds on the horizon of classical physics" were solved by the discovery of quantum physics and triggered its development. One must not forget that quantum theory started with Planck's solution of the black-body radiation problem, a typical statistical-physics problem, and Einstein's idea about "wave-particle duality" (although obsolete now) came from his analysis of this solution.
  • #92
There isn't something unclear about what you probably would call the physics. The last couple of posts were just concerned with how the Copenhagen interpretation fits in with what I wrote in post #79. This could be a starting point for another fundamental discussion about interpretations but I don't want to lead such a discussion right now.
  • #93
That sounds like the Weinberg's proof of the H-theorem, in
S. Weinberg, The Quantum Theory of Fields vol I, Sec. 3.6, pages 150-151.
Can you explain why at the left hand side of Eq. (3.6.19) we have dt and not d(-t)? The sign of t should not matter in a T-invariant theory. On the other hand, with d(-t) in Eq. (3.6.19) we would eventually "derive" that entropy decreases with time, contrary to what we wanted to obtain.
My point is, you cannot really derive the H-theorem without assuming some form on time asymmetry from the beginning.
  • #94
atyy said:
No, what I said was that being unquestionably right was a criterion for teaching it to undergraduates.
Well, it was a light-hearted comment but if you want to be serious about it, perhaps you can say which version of CI you regard as unquestionably right. CI tends to be an umbrella for all sorts of interpretations including Heisenberg fuzziness which inspired Schrödinger's Cat. However as far as I know, CI always has some sort of randomness built into it, whether as a projection postulate or a slightly simpler wavefunction collapse. MW manages without any such thing. So it would seem that CI actually has redundant hypotheses making it pretty unlikely to be right at all, let alone unquestionably so.
  • #95
This is precisely the one and only correct proof of the detailed-balance relation for the most general case. You don't need time-reversal or parity invariance at all. I also don't understand your question concerning dt vs d(-t), because there's no time integral involved in (3.6.19). You just integrate (3.6.19) over ##\mathrm{d} \alpha##. Then both integrals are equal, and thus ##\int \mathrm{d} \alpha P_{\alpha}## time-independent.
However, your final statement is correct: Of course in deriving transition-matrix elements you assume a directnesses of time, the socalled "causality time arrow". The H theorem just proves that this "causality time arrow" is the same as the "thermodynamical time arrow", defined as the direction of time, where entropy doesn't decrease.
Of course, a system in thermal equilibrium doesn't admit the determination of any time direction, because it forgot any history. In other words, if you make a movie from a equilibrium system, you cannot tell whether you show it forward or backward running, as long as you look at the macroscopic state only, i.e., averaged/coarsegrained quantities.
  • #96
uumlau said:
Note that EPR, Bell's inequality and entanglement don't demonstrate "nonlocality" (though this is the common word for it) so much as it confirms the initial "superposition of states" as predicted by quantum mechanics. In other words, the initial state of the photons are not polarized in a particular direction, the initial spin of the fermions are not in some specific x-y-z direction. The "nonlocalitiy" has to do with those states being 100% correlated antisymmetrically, as required by standard quantum mechanics.
Like others in this thread, I'm not seeing anything that looks like "proof of wave function collapse". It's called "proof of existing quantum theory." There is an unfortunate tendency in physics to conceive of the math as being the reality. The math is the description of the reality, the quantitative language we use to communicate about the reality, subject to experimental verification.
Or to use an analogy from the Matrix, the quote of "There is no spoon." There is no wavefunction. There are phenomena that we measure that are described by math we call "wavefunctions", which aptly predict our measurements. The notion that you can "prove" that a mathematical construct has objective material behavior (collapsing or otherwise) is absurd.
  • #97
The wave function collapse is a value exchange - a numerical event!
  • #98
The OP is long gone and now the discussion is just going in circles. Thread closed.
  • · Replies 20 ·
  • · Replies 33 ·
  • · Replies 59 ·
9K
  • · Replies 18 ·
