Newton second law involving a gallon of water
The problem involves a box filled with water on an incline plane, where the mass of the water decreases over time due to a leak. The scenario includes a force applied to move the box up the incline, and participants are tasked with determining the final velocity of the box as it moves up the incline.
  • Mixed
  • Participants discuss the implications of variable mass on Newton's Second Law, questioning how to apply the law when mass is not constant. Some express confusion regarding the specifics of the problem, particularly the nature of the mass being referred to (gallon vs. kilogram).
There is ongoing exploration of the problem with various interpretations of the mass involved. Some participants have provided insights into the application of Newton's Second Law in cases of variable mass, while others are seeking clarification on the initial conditions and parameters of the problem.
Participants note the importance of understanding the mass change over time and question the relevance of the specific volume of water in the context of the problem. There is also mention of how the leaking mass affects the overall dynamics of the situation.
kadoma
a box filled of water is over at the beginning of a incline plane of 30 degree, it has a mass of 1 kg,from the bottom of the plane to the top is 10m, the gallon is pushed with a force of 10N to the top, and the gallon is leaking 0.01kg per second
what is the final velocity?
f=ma
analyzing this problem each since the force doesn't change, the mass decrease each second so the acceleration increase each second. i really don't know how to solve this problem when involving a gallon of water leaking.
Only when the mass remains constant does Newton's Second Law of motion reduce to
\vec{F}=m\vec{a}
When dealing with variable mass, use
\vec{F}=\frac{d}{dt}(m\vec{v})
\vec{F}=m\vec{a}
so it means the mass is constant, it only changes the velocity
No, the mass is not constant. It is changing with time. Also, did you copy the question down fully, and properly?
well if you don't understand my question u can ask me
as far i understand time is changing as well as mass and velocity
\vec{F}=m\vec{a}
This equation is known to be incorrect in general, although it is true in some cases. Correct classical variable-mass equations of motion were finally well established in the 1990s! Before that, many incorrect results appeared in the published literature. Google 'variable-mass dynamics' for relevant papers.
RGV
so... this is harder now, can u help me?
kadoma said:
a gallon of water is over at the beginning of a incline plane of 30 degree, it has a mass of 1 kg,from the bottom of the plane to the top is 10m, the gallon is pushed with a force of 10N to the top, and the gallon is leaking 0.01kg per second
f=ma
A couple of questions:
Is this a gallon of water or a kilgram of water? A litre of water has a mass of 1 kg.
If this is a gallon, is this a US gallon [8 lb] or an imperial gallon [10 lb],
EDIT: I ask about which gallon as I don't know where you are posting from.
RGV
Interesting to know.. Especially considering this was in my Calculus textbook from January 2009.
actually is not really a gallon of water...is just a box or tank filled with water which leak every second.
i'm pretty sure that the volume isn't important just the change in mass
If the box was not leaking, it would take only about 2 seconds to reach the top, arriving with a velocity of about 10 m/s.
In two seconds, the mass will have reduced from 1.00 kg to 0.98 kg - a very small change, so the final velocity won't be much bigger.
Since data was given to one specific figure only, the answer should be 1 x 101 regardless.
i already solved it
  • · Replies 42 ·
