Newton's 2nd Law: Calculate Mass of Cart
The problem involves a cart influenced by a force, moving a certain distance with and without an additional weight. The objective is to calculate the mass of the cart based on the distances traveled and the weight added.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss methods to determine acceleration and force, questioning the relationship between displacement, time, and acceleration. There are attempts to derive velocity and acceleration from given distances.
The discussion is ongoing, with participants exploring various interpretations of the problem and the implications of constant velocity versus constant acceleration. Some guidance has been offered regarding the relationships between force, mass, and acceleration, but no consensus has been reached.
Participants note the ambiguity in the problem statement regarding the nature of the force acting on the cart and the assumptions about acceleration. There are concerns about the completeness of the information provided for solving the problem.
Igniuxx6
Influenced by certain force, cart moved from place and driven 0.5 meters distance. When 200grams weight was placed on cart it moved 0.3 meters during the same period of time. Calculate the mass of the cart.
So, how did you tried?
Tried to get acceleration by converting grams to kilos, then dividing 0,3 meters with 0,2 kilos. Got 1,5, but I doubt its right. If 1,5 would be correct, I would just use ΣF⃗=ma⃗
Then, why do you need the acceleration? I know you want to use the Newton's second law, but there are many missing parameters to use this.
I want acceleration to get force and with Force + Acceleration I would get mass. So what I should use instead? Pretty lost,
In this statement, I can get the velocity of cart and cart + 200grams weight, roughly. But I don't know how to get the acceleration.
How about a1=V1-V01/t a2=V2-V02/t that leads to (V1-V01)*t/t*(V2-V02), we cancel out t and we get (V1-V01)/(V2-V02), now I need to know how you get velocity of cart and cart + 200grams.
You know the displacements. Assuming uniform acceleration, how is the displacement related to time and the acceleration?
Displacement moves same distance each time interval
What you means is the constant velocity. Is this problem settle down with constant acceleration or constant velocity?
You mentioned you are abble to get velocity, if you would tell me how, I (maybe) would be abble to get acceleration from there and use it to get mass.
I supposed the cart moves without acceleration, that is constant velocity. Since we know the displacement within unknown time interval ##T##, I can only tell you that the velocity is in a form ## 0.5 m / T ##.
The problem statement is:
If a certain force takes place, the velocity is not constant.
I thought the certain force only acted at the initial and the cart moves freely. But, it seems you are right. My poor English sometimes confuse me.
Ok, then now I am clear.
The cart with mass ## M ## and cart + weight with mass ## M + m## moved by a fixed certain force ## F## and the displacements are ## d_1 ## and ## d_2 ##, respectively.
That is true now.
But this is Igniuxx6's thread. Do not confuse him, and do not try to solve his problem. Both are against the rules of these Forums.
So
m2=0,2kg
m=m1+m2
F=d1+d2/m2=0,5+0,3/0,2=4N
a=F/m2=20
m1=F/a=4/20=0,2kg
m=0,2+0,2=0,4kg
In constant acceleration, the displacement is well known and because we know the displacement, you can get the acceleration.
This part is really strange. Why don't you check the relevant equations?
So its like a=9,8?
So it would be :
F=m*a=0,2*9,8=1,96N
m1=F/a=1,96/9,8=0,2kg
m=0,2+0,2=0,4kg?
For example, the displacement with constant velocity is given by ## d = v t. ## What about the displacement with constant acceleration?
d = at? or d = 1/2at^2
  • · Replies 24 ·
