Newton's 2nd Law for a Particle in Uniform Circular motion
The discussion focuses on calculating the tension in two strings supporting a 4.0 kg object rotating in a horizontal circle at a constant speed of 6.00 m/s. The object is subjected to centripetal force, which is derived from the equation F_c = mv^2/r. Participants emphasize the importance of summing forces in both the x and y directions to determine the tensions in the upper and lower strings, ultimately applying Lami's theorem to solve for T1 and T2. The final calculated tensions are approximately 69 N for the upper string and 56.2 N for the lower string.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of centripetal force equations (F_c = mv^2/r)
  • Familiarity with vector components and free body diagrams
  • Application of Lami's theorem in equilibrium problems
  • Study the derivation and application of Lami's theorem in physics problems
  • Learn to draw and analyze free body diagrams for complex systems
  • Explore centripetal force calculations in different contexts, such as roller coasters or satellites
  • Investigate the effects of varying mass and speed on tension in circular motion
Physics students, educators, and anyone interested in understanding the dynamics of circular motion and tension in systems involving multiple forces.
clintau
1. A 4.0kg object is attached to a vertical rod by 2 strings. Object roatates in a horizontal circle at a constand speed 6.00 m/s. Find the tention in the upper and lower string. The strings are 2 meters long. the distance between the attachment points for each string is 3 meters.
2. F=ma=m(v^2/r)
3. I know that you must sum the forces in the x and y direction but can't seem to get rolling on this
Yes, you must sum the forces from both strings. The sum of the forces is a net centripetal force. What does this mean it has to be equal to?
HINT: What are all centripetal forces equal to?
i don't know.
Draw a vector diagram...then split the tension into it's components.
Y direction
Fupper= T*cos(theta)+mg=0
Flower= T*cos(theta)-mg=0
yes no?
clintau said:
i don't know.
Yes, you do. You said it in your first post.
F_c=mv^2/r
So, if:
\Sigma F_{radial direction} = F_c and F_c=\frac{mv^2}{r} then...
Also,
You need to sum the radial components (x components) of the forces, since only those will contribute to the net centripetal force. To find these it would help to draw a free body diagram as clintau said. How far can you get now?
so Fc=4*6^2/r=109.09
That gives the force in the x direction...What about the Y?
how would you find the tensions in the strings?
\Sigma F_{vertical}=0
Fcx is the T in the upper string. How do you get the T in the lower?
Tupper-mg? gives app 69N. Answer should be 56.2
what is wrong?
clintau said:
Y direction
yes no?
Instead of taking componets of tention on Y direction, take the component of mg along the tensions.
So T(upper) = T1 + mgcos(theta)
T(lower) = T2 - mgsin(theta)
Now T(upper), T(lower) and Fc are in equilibrium. Apply the Lami's theorem.
[T1 + mgcos(theta)]/sin(pi/2 + theta) = [T2 - mgsin(theta)]/sin(pi/2 + theta) = [mV^2/r]/sin(pi -2*theta).
Now solve for T1 and T2.
  • · Replies 42 ·
  • · Replies 17 ·
9K
  • · Replies 17 ·
