Newton's 3rd law and kinetic friction
The discussion focuses on solving a physics problem involving Newton's 3rd law and kinetic friction. The problem requires calculating the minimum force (Fmin) needed to pull a board from under a box resting on it, where the box has mass m1 and the board has mass m2. Key equations derived include the acceleration of the box (a = usg) and the relationship between applied force and friction for both the board and the box. Participants emphasized the importance of correctly applying free body diagrams (FBD) to isolate forces acting on the board and the box.
  • Understanding of Newton's 3rd law of motion
  • Knowledge of free body diagrams (FBD)
  • Familiarity with static and kinetic friction coefficients
  • Basic algebra for rearranging equations
  • Practice problems involving Newton's laws and friction
  • Study the derivation of equations for systems with multiple masses
  • Learn about the implications of static vs. kinetic friction in real-world applications
  • Explore advanced topics in dynamics, such as acceleration and force interactions
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of forces and motion in systems involving friction.
sunbunny
Hi, I'm having problems solving this problem:
A small box of mass m1 is sitting on a board of mass m2 with length L . The board rests on a frictionless horizontal surface. The coefficient of static friction between the board and the box is us. The coefficient of kinetic friction between the board and the box is us.
Throughout the problem, use for the magnitude of the acceleration due to gravity.
Find Fmin., the constant force with the least magnitude that must be applied to the board in order to pull the board out from under the the box (which will then fall off of the opposite end of the board).
Express your answer in terms of some or all of the variables us ,m1 ,m2 ,g ,L and . Do not include Force of friction in your answer.
This is what I've done:
I know that acceleration of board must be larger than the acceleration of the box.
I've found the acceleration of the box to be a=Ff/m1 which then equals
a= usg
now i need to find the acceleration of the board.
I've found that Fx=F-Ff
I changed the Ff into usm2g
F-usm2g=max
then i changed m into m1 and m2 because the board has both masses
f-usm2g=m1m2a
then for a I got:
a=f-usm2g/m1m2
however this is wrong. if anyone can help me with this that would be great thanks
sunbunny said:
a= usg
I changed the Ff into usm2g , incorrect, think Newton 3 for the friction force between box and board[/color]
F-usm2g=max
f-usm2g=m1m2a
then for a I got:
a=f-usm2g/m1m2
You are mixing up your free body diagrams. If you are going to isolate the board, do not include the mass of the block. If you are going to isolate the system, do not include the friction force between the block and board.
So for the board, would i just include a normal force, weight force, and the force applied
No, if you're just looking at the board in a FBD, you have the applied force acting right, and the friction force between box and board acting left. You have the weight and normal force also, but you don't need them here to solve. The masss is just m2. Alternatively, look at the block and board system as a FBD. then you just have the applied force to consider, but the mass is (m1 + m2.)
okay so would this make the horizontal component of the FBD for the board:
max=Fapplied,x - Ffriction,x
(m1+m2)a=Fapplied,x-usm2g,x
a=Fapplied,x-usm2g,x/(m1+m2)
Ah, there you go again mixing up your FBD's. For the board, m2a= Fapplied - usm1g
For the box, m1a = usm1g
and check your work with a FBD of the system, (m1 +m2)a = Fapplied
Now you've got more than enough equations to solve for F. Note that for applied forces greater than F, the block will start to slide. This is sometimes not easily understood.
okay, I'm starting to see how it's done and how I've mixed up my FBD. I think I just need to practice some more problems.
I rearanged the m1a=usm1g to a=usm1g/m1
i then substituted this value for a into:
Fapplied=m2a+usm1g
Thanks so much for your help, I really appreciated it! Now I'm going to try some more practice problems while it's fresh in my mind. thanks again!
Fapplied=m2a+usm1g
Fapplied=m2a+usm1g
Fapplied=m2a+usm1g
Fapplied=m2a+usm1g
oh wow I'm sorry i didn't mean to put that many up, i don't know what happened
you're welcome^5!
  • · Replies 19 ·
12K
