Newtons first law should not be termed an expression of inertia
This discussion centers on the assertion that Newton's First Law should not be termed an expression of inertia. Participants argue that inertia is a fundamental property that defines the law itself, as articulated in Isaac Newton's "Principia." The debate includes hypothetical scenarios involving the removal of inertia and the implications for motion, ultimately concluding that Newton's First Law remains valid regardless of inertia. The consensus is that inertia is intrinsically linked to the law, and any claims to the contrary lack scientific foundation.
  • Understanding of Newton's First Law of Motion
  • Familiarity with the concept of inertia as a property of matter
  • Basic knowledge of force and its units (mass, distance, time)
  • Introduction to calculus, particularly derivatives
  • Research the historical context of Newton's "Principia" and its impact on classical mechanics
  • Study the relationship between mass and inertia in physics
  • Learn about the mathematical representation of force, including F = ma
  • Explore advanced topics in physics, such as relativistic effects on mass and inertia
Physics students, educators, and enthusiasts seeking a deeper understanding of classical mechanics and the foundational principles governing motion.
johann1301
LAW I.
EVERY BODY PERSEVERES IN ITS STATE OF REST, OR OF UNIFORM MOTION IN A RIGHT LINE, UNLESS IT IS COMPELLED TO CHANGE THAT STATE BY FORCES IMPRESSED THERON. - «Isaac Newton`s Principa»
In case inertia could be removed from a body (e.g by a relative of Maxwell`s demon), the following situation is presumably true;
PART I
1. A body B has a state of uniform motion in a right line
2. Inertia is removed from the bodies mass
3. The bodies state of motion is unchanged*
PART II
4. Another (inertial)body A comes in contact with Body B
5. This contact causes B to change in its state of motion which is described as mass over a distance per second squared. Also known as force.
I conclude the following about LAW I;
PART I
Every body perseveres in its state of uniform motion in a right line regardless of inertia.
PART II
Any body can be compelled to a change in its state of motion by forces regardless of inertia.
Newtons first law is therefore independent of inertia and should not be termed an expression of inertia or «the law of inertia».
Some examples where LAW I is termed an expression of inertia;
http://www.khanacademy.org/video/Newton-s-first-law-of-motion?playlist=New and Noteworthy
Science news on Phys.org
Your post is hardly coherent... but it seems you just don't understand what 'inertia' is.
'Inertia' (as you can find from a simple google search), is not a physical thing---its a property, or a 'tendency'. In particular, 'intertia' IS exactly Newton's first law. In other words, Newton's first law defines 'inertia'.
If:
F = 0
Then:
ma \sim \Delta (mv) = 0
Edited equation for clarity
That is inertia.
What? Maxwell's demon removed certain types of particles from an ensemble of many... how do you remove inertia from an object without exerting a force upon it?
PART I
You don't 'remove inertia from mass'.
You put an '*' on part '3' without expanding... '3' is also completely false. Inertia is an objects state of motion.
johann1301 said:
PART II
This isn't really related to the overall point, but force is in units of mass * distance per second squared.
For the record; random videos aren't especially pertinent sources or references...
What does
Δ(mv)
stand for?
The mark(*) is there because i don't know if the statement is true.
I figure you do;
johann1301 said:
What does \Delta(mv) stand for?
The 'Delta' (\Delta) refers to a 'change in' a parameter. A more exact statement would have been \frac{d}{dt} (mv) = 0 which means, the derivative* of the mass times the velocity. If the mass is constant, this simplifies to
\textrm{if} \hspace{0.2in} \frac{d}{dt} m = 0 \hspace{0.2in} \textrm{then} \hspace{0.2in} \frac{d}{dt} (mv) = m a
Where the acceleration is the derivative of the velocity.
* If you are unfamiliar with derivatives, its basically the instantaneous rate of change of something.
ΔZHermes: Force has units based on mass, distance and time squared. Not what you said.
Your equation: ma = Δ(mv) is incorrect.
It should read ma = m(Δv/Δt).
johann1301: Δ(mv) is more commonly and correctly written as mΔv and means change in momentum.
To start changing mass by breaking off bits or whatever changes the object in discussion so that it is neither Object A nor Object B any more.
Thanks @daqddyo, fixed and clarified these respectively.
I understand why you disagree and find my demon silly. Its not possibly to remove inertia from matter.
If i said;
Lets say that some day we find a rock from space which is made of matter/mass but has no inertia. I know, its a stupid thought. (but imagine that! wow!)
Why should or would we think that it would be an exception from Newtons first law of motion?
My answer is; it wouldn't be an exception from the law, it would follow the law exactly. Is there any reason to think anything else?
If i said;
This is one of the most meaningless waste-of-time discussion that I've ever seen on this forum.
1. You have not shown ANY physics that decouples mass from inertia.
2. Yet, without showing #1, you THEN somehow make this outlandish assertion of "what if".
This thread is in clear violation of the PF Rules on over-speculative post.
Zz.
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 19 ·
  • · Replies 35 ·
  • · Replies 17 ·
