How Do You Calculate Initial Temperature Using Newton's Law of Cooling?
The discussion focuses on calculating the initial temperature of an object using Newton's Law of Cooling. The fixed room temperature is 30 degrees Celsius, with the object's temperatures recorded at -10 degrees Celsius after 10 minutes and -5 degrees Celsius after 20 minutes. The relevant equations are y(t) = b + Ce^(-kt) and dy/dt = -k(y - b). By manipulating these equations, participants suggest solving for the constants k and C to determine the initial temperature.
  • Understanding of Newton's Law of Cooling
  • Familiarity with exponential functions and natural logarithms
  • Basic algebra skills for manipulating equations
  • Knowledge of calculus concepts, specifically derivatives
  • Study the derivation and application of Newton's Law of Cooling
  • Learn how to solve exponential equations involving natural logarithms
  • Explore the concept of differential equations in physical contexts
  • Practice problems involving temperature change over time using real-world scenarios
Students studying physics or mathematics, particularly those tackling problems related to heat transfer and cooling processes.
D-Boy
A small object of unknown temperature was placed in a large room that had the fixed temperature 30 degrees C. After 10 minutes, the object's temperature is -10 degrees C, and after an additional 10 minutes, the object's temperature was -5 degrees C. What was the initial temperature of the object?
b = 30
When t = 10, y = -10
When t = 20, y = -5
y(t) = b + Ce^(-kt)
dy/dt = -k(y - b)
When I plug in the knowns of the variables I get either the equation:
-10 = 30 + Ce^(10k)
-or-
-5 = 30 + Ce^(20k)
I'm confused how I can find the constant k value and the constant C value when I'm not given the initial temperature. If someone can help me find either of the constant values I can probably work from there to finish the rest of the problem. Thanks
When I plug it in I get -10 = 30 + Ce^{-10k}, -5 = 30 + Ce^{-20k}
Now, for each separate equation, take b to the other side, divide through by C, take a natural log, then divide by the coefficient of k. In short - Solve for k. You get two equations for k, set them equal to each other and simplify, you can solve for C. Once you solve for C, sub that into one equation and solve for k.
15K
11K
19K
15K
