Newton's Laws: Simple Constant Force Problem
The discussion revolves around a problem involving Newton's laws, specifically focusing on a car's deceleration due to braking. The original poster presents a scenario where a car weighing 12000.0 N is brought to a stop from an initial speed of 30.0 km/hr in a specified time frame.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of force and distance traveled during deceleration. There is confusion regarding the correct time duration for the calculations, with some participants questioning whether it should be 4.1 seconds or 4.6 seconds. Others share their methods for calculating acceleration and force, while one participant expresses difficulty in solving a similar problem.
The discussion is active, with participants providing various approaches to the problem. Some guidance has been offered regarding the use of formulas for acceleration and force, but there is no explicit consensus on the correct time duration or the final distance calculation.
There is a noted discrepancy in the time duration used for calculations, which may affect the results. Additionally, participants are working with different numerical values in similar problems, contributing to the complexity of the discussion.
anastasiaw
A car that weighs 12000.0 N is initially moving at a speed of 30.0 km/hr when the brakes are applied and the car is brought to a stop in 4.1 s. Find the magnitude of the force that stops the car, assuming it is constant.
Figured this one out, got: v0 = 8.33 m/s, a = -2.03 m/s^2, F = 2.49 X 10^3 N
What distance does the car move during this time?
This is the one I'm having trouble with.
Using: x(t) = x0 +v0*t + 1/2*a*t^2 and x0 = 0
x(t) = 0 + 8.33(4.6) + 1/2(-2.03)(4.6^2)
x(t) = 16.83 m
Tells me I am wrong. I don't know what to do from here.
"brought to a stop in 4.1 s"
x(4.6) = 0 + 8.33(4.6) + 1/2(-2.03)(4.6^2)
Maybe that's the problem XD
Sorry, is the time 4.6 s or 4.1 s?
EDIT: Got beat. LOL.
Thanks... :)
17.1 m is the answer.
How did you solve the first part? i have the same problem with different numbers and am having trouble with it.
Thanks
The formula I used to calculate acceleration was:
a = (v - v0) / t
a is acceleration,
v is final velocity (should be 0 m/s),
v0 is initial velocity, which you must convert to m/s,
t is the time it takes to stop.
You can then use the very important equation
F = ma
to calculate the magnitude of the force that stops the car.
You will need to convert the weight given in Newtons to kilograms. You can do this using the same equation as above, with the acceleration in this equation as the acceleration due to gravity.
  • · Replies 42 ·
