Why Is the Center of Newton's Rings Dark?
The center of Newton's rings appears dark due to the phase difference between two reflected rays, despite the path difference being zero when the surfaces are in contact. As the surfaces are separated, the path difference can change, but the phase difference remains significant, leading to destructive interference at the center. This phenomenon is critical in understanding the behavior of light in thin films and interference patterns.
  • Understanding of wave optics principles
  • Familiarity with interference patterns
  • Knowledge of phase difference in light waves
  • Basic concepts of thin film interference
  • Study the principles of thin film interference in detail
  • Explore the mathematical derivation of Newton's rings
  • Learn about the applications of interference patterns in optical instruments
  • Investigate the effects of varying air gap thickness on interference
Students of physics, optical engineers, and anyone interested in the principles of light interference and wave optics.
sheld
Why the center of Newton's ring is dark? though I am thinking the path difference in the center is zero between two reflected rays...
so,I will be glad if you give the correct information about that...
As long as the surfaces are in contact the path difference in the middle is zero. If you move them slightly apart you can change this.
so,I will be glad if u give the correct information about that...
The phase difference between the two reflected ways counts, and it is not zero, even in the case when the path difference --->0.
  • · Replies 35 ·
