How to Determine the Liquid's Refractive Index in a Newton's Rings Experiment?
  • Thread starter Thread starter ChrisWM
    Optics Rings
The discussion focuses on calculating the refractive index of an unknown liquid using the Newton's rings experiment. Given the diameter of the fourth bright ring in air at 10.0 mm and the diameter in the liquid at 8.45 mm, the refractive index can be determined using the equation xm=√mλfR. The assumption is made that the liquid's refractive index is less than that of glass, which is critical for accurate calculations.
  • Understanding of Newton's rings experiment
  • Familiarity with the equation xm=√mλfR
  • Knowledge of refractive index concepts
  • Basic optics principles related to light interference
  • Research the derivation of the Newton's rings formula
  • Learn about the properties of light interference in thin films
  • Study the application of refractive index in optical materials
  • Explore experimental setups for measuring refractive index
Students in physics or optics courses, educators teaching light interference, and researchers interested in optical properties of liquids.
ChrisWM
Poster has been reminded to show their work on schoolwork problems
Consider a Newton's ring experiment in air. The diameter of the fourth bright rings 10.0mm. When an unknown liquid is poured into the gap between the lens and the support, the diameter of this ring shrinks to 8.45 mm. Calculate the liquid's index of refraction. Assume that the liquid's refractive index is less than the index of refraction of glass (used for the lens and bottom plate).
xm=√mλfR.
I have no idea where to start with this. My professor didn't give an example and I am very confused.
ChrisWM said:
Homework Statement:: Consider a Newton's ring experiment in air. The diameter of the fourth bright rings 10.0mm. When an unknown liquid is poured into the gap between the lens and the support, the diameter of this ring shrinks to 8.45 mm. Calculate the liquid's index of refraction. Assume that the liquid's refractive index is less than the index of refraction of glass (used for the lens and bottom plate).
Relevant Equations:: xm=√mλfR.
What is the equation for the radius of the Nth ring?
https://en.m.wikipedia.org/wiki/Newton's_rings#Theory
  • · Replies 151 ·
