How Does Newton's Second Law Apply to Highway Safety?
The discussion focuses on applying Newton's Second Law to highway safety by calculating safe distances and stopping times for a car in a potential collision scenario. The initial calculations for the safe distance were incorrect, with a suggested distance of 1200 m instead of the correct 40 m based on the car's speed. The braking force and time to stop were also miscalculated, leading to an unrealistic stopping time of 226.4 seconds. Participants emphasized the importance of unit conversion and using kinematic equations correctly to ensure accurate results. Overall, the conversation highlights the critical need for precise calculations in assessing highway safety to prevent collisions.
oMovements
The minimum safe distance between vehicles on a highway is the distance a vehicle can travel in 2.0s at a constant speed. assume that a 1.2x10^3 kg car is traveling 72km/h when the truck ahead crashes into a northbound truck and stops suddenly.
a) if the car is at the required safe distance behind the truck, what is the separation distance?
b) If the average net braking force exerted by the car is 6.4x10^3 N [N], how long would it take the car to stop?
c) Determine whether a collision would occur. Assume that the driver's reaction time is an excellent 0.09s.
The attempt at a solution
3a) d = (vi+vf/2) t
= (1200+0/2) (2)
= 1200 m
b) Fnet = m*a
-6.4x10^3 = (1.2x10^2)a
a = -5.3 m/s^2
a = vf-vi/t
-5.3 = 0-1200/t
t = 226.4s
c) d = vit + 1/2at^2
d = (1200)(0.09) + 1/2 (-5.33)(0.09)^2
d = 108m
Which is the distance traveled in reaction
d = vit + 1/2at^2
= (1200)(225) + 1/2(-5.33)(225)^2
= 2.7x10^5 - 134915
= 135084m m
d = 13504 + 108
= 125192 m
so a collision would occur
Is this correct?
The first question, as I understand it, just requires the distance the car will go at 72Km/h in 2 seconds which is 2 times 72/3600. i.e. 40m. Your answer of 1200 m ( about a mile) is obviously wrong.
Part b),
a = f/m
v = v0-at -> when v=0 t=v0/a = 72m/f.
In 32a) to find the distance, you seemed to have used the mass of the car, in place of its velocity. That being said, i think your equation could be modified. The question is relating to the distance between the car and truck while in motion. the velocity remains constant.
distance = (velocity)x(time),
*make sure to convert the components into correct units. (km/h) -> (km/s) (since time is given in seconds)* *you will get a distance in terms of (km) when you do this, which you can then convert to (m) if you feel so compelled*
in b) When dealing with forces, it always helps to draw a force body diagram, letting you visualize the situation and see which direction the forces are going. This always helps me in determining the correct signs as well.
You have a force in the left direction, (by convenience, placing the car's velocity along the positive x-axis), meaning your stopping force is going to be negative.
-Fnet = mcar x (-)a
This should make sense as the car is slowing down, the force is in the negative direction, and the car is accelerating to the left.
While you have the correct signs, you seemed to have neglected to convert the (km/h) of the velocity, into the (km/s) needed, since your time component is in seconds. It always helps to think about you answers in terms of the situation. With the time you have written down in your answer, it means it will take the car 226.4 seconds to come to a stop. (Which means it will take you over 3 minutes to come to a stop!) So i would always beg you to make sure you answer makes sense to the situation.
in 3c) you seemed to have done the kinematic equations correctly in this and the equations make sense in that the driver will travel a distance during reacting, and will also travel a distance during the braking, but again avoided to convert the (km/h) of the velocity, into (km/s). In order for the units to cancel, the time parameters must match. *Write down your units as well as the value into the equations, to make sure they cancel correctly, and that you finish with what you need! :-p * I hope this helps!p.s. - Welcome to PF!
-Fnet = mcar x (-)a
Thanks, worked out the question and the answer makes sense. :)
  • · Replies 41 ·
