Newton's second law and the egg drop
In summary, the conversation discusses the application of Newton's second law to a system consisting of a box, egg, and padding. The force applied to the box is distributed to the egg through the padding, preventing it from cracking. The conversation also touches on the confusion about whether the force on the egg is the same as the force applied to the box. The expert clarifies that the force is indeed acting on the egg, but it is spread out over the surface of the egg to prevent it from cracking.
Gamma
357
Hi,
I have a question on Newton's second law.
I have a box in which an egg rests inside. Egg is surrounded by some sort of padding. A force is applied to the box. (Force has an x and -y component.
Are my conclutions right?
1) Force act on the box, not on the egg. Applying Newton's second law to the whole system one can get the system's accelertation,
F = (m1 + m2 ) a
2) Net force on the egg = zero. Egg does not move.
3) What does the padding do? Is it to avoid the egg moving at the beginning of the application of the force? At the beginning, due to Newton's third law, egg will move against the applied force and go hit the back of the box. So if I gradually increase the applied force can I avoid the padding?
(4) Force applied in the negative y direction would make it difficult to move the box.
I get confused with my first statement. Technically egg moves with respect to a person out side the box. So the egg shoud have accelerated which means egg shoud be experiencing a force?? How to clear my confusion?
Please pour in your knowledge on this egg problem. I know egg box system is a very common school problem in USA.
Thank You.
Gamma.
Gamma said:
Hi,
F = (m1 + m2 ) a
Okay, you are treating the box, egg, and padding as a single system. I would have preferred you told us what m1, m2 mean (there are actually three masses- box, egg, padding).
relative to what? The egg does not move relative to the box but since the "box,egg,padding" have acceleration a (relative to the boxes original position), so does the egg.
The padding spreads the force over the entire surface of the egg. It's a mistake to think of it as having to do with time. "Gradually increasing the applied force", just means you start with low force which, hopefully, would be low enough not to crack the egg even without padding spreading the force. Of course if you continued increasing the force, eventually it would become enough to crack the egg.
If your box is sitting on a surface with non-zero friction coefficient, then, yes, friction is proportional to the normal force.
Yes, the egg is accelerated so the egg is experiencing a force. You push against the box, the box pushes against the padding, the padding pushes against the egg. As I said before, the padding spreads the force over the surface of the egg so there is no force at anyone point on the egg enough to crack it.
Thank You.
Gamma.
Thank you,
F = (m1 + m2 ) a
Yes, I should have included the weight of the padding.
After your suggestions, my new conclutions are:
(1) F = (m1 + m2 + m3) a
(2) Egg experiences the applied force.
If the applied force is F = Fx + Fy (x and y componetns of the applied force)
Net force on the egg in horizontal direction is Fx.
Net force in the vertical direction is N + Fy - mg
However, these forces are uniformly distributed over the surface of the egg so that the egg would not crack.
(3) If I apply Newton's second law to the egg only,
Fx = m(egg) a where a is given by F = (m1+m2+m3) a
N + Fy - mg = 0
Please let me know if these conclutions are correct. Thank you in advance.
Gamma.
So what you mean is that the applied force act on the egg too. Please look at the following.
Newton's second law applied to the whole system horizontally,
Fx = (m1 +m2+m3) a ---------------(1)
(m1 mass of the egg, m2 mass of the padding, m3 mass of the box)
If we apply Newton's second law to only the egg,
Fx = m1 a
-----------------------(2)
(m1=mass of the egg)
If we look at (1) and (2) they both can't be true. We know egg's acceleration is a. This means, force on the egg can not be Fx?
This is the confusion I have.
Please explain some one. Thanks,
Gamma.
1. What is Newton's second law?
Newton's second law states that the force acting on an object is equal to its mass multiplied by its acceleration. In other words, the greater the mass of an object, the more force is needed to accelerate it.
2. How does Newton's second law apply to the egg drop experiment?
In the egg drop experiment, the force of gravity acting on the egg is the same whether it is dropped from a low or high height. However, the acceleration due to gravity increases as the egg falls from a higher height. This means that the egg will experience a greater force upon impact, potentially causing it to break.
3. What is the relationship between mass and acceleration in Newton's second law?
The relationship between mass and acceleration in Newton's second law is inverse. This means that as the mass of an object increases, its acceleration decreases and vice versa. This is because a greater mass requires more force to accelerate it at the same rate as a smaller mass.
4. How can Newton's second law help us understand the outcome of the egg drop experiment?
Newton's second law helps us understand that the outcome of the egg drop experiment depends on the mass of the egg and the force of gravity. If the egg has a greater mass, it will require more force to accelerate it and prevent it from breaking upon impact. This is why materials such as packing peanuts or a parachute can be used to decrease the acceleration and prevent the egg from breaking.
5. Can Newton's second law be applied to other real-life situations?
Yes, Newton's second law can be applied to a variety of real-life situations, such as calculating the force needed to push a car or the acceleration of an object in free fall. It is a fundamental principle in physics and is used to understand the motion and forces acting on objects in our everyday lives.
