NGC7741 Imaging: Should I Stack Images Through IRAF?
  • Context: Undergrad
  • Thread starter Thread starter starstruck_
    Images Imaging
The discussion revolves around the challenges of stacking images of the galaxy NGC 7741 using various software tools, particularly IRAF and DeepSkyStacker. Participants explore issues related to image visibility, light leaks, and the requirements for successful stacking, as well as potential software alternatives for image processing and data reduction.
  • One participant expresses confidence that their galaxy will appear after stacking images, despite only seeing a few stars in initial checks.
  • Another participant suggests that there are software options that require fewer stars for stacking, prompting inquiries about specific programs.
  • Several participants mention software alternatives like AIP4Win, CCDOPS, and Registax, which allow for manual stacking or require fewer stars.
  • DeepSkyStacker is recommended multiple times as a free and versatile option for stacking images.
  • Concerns are raised about light leaks affecting the visibility of the galaxy, with participants discussing the implications of these leaks on the final stacked images.
  • Participants discuss the importance of proper image stretching and calibration images (bias, dark, and flat) to address issues like light leaks.
  • One participant notes that stacking alone will not reveal faint objects if they are not visible in single frames.
  • There are suggestions for using plate solving programs to assist in image alignment.
Participants express a range of views on the effectiveness of different software for stacking and the impact of light leaks on image quality. There is no clear consensus on the best approach to take, and multiple competing views regarding software options and techniques remain present throughout the discussion.
Participants mention various software tools and techniques, but there are limitations in their knowledge and experience, particularly regarding the specifics of IRAF and the nuances of astrophotography. The discussion also highlights the challenges of dealing with light leaks and the need for proper calibration.
This discussion may be useful for amateur astronomers, astrophotographers, and students interested in image processing techniques for astronomical data, particularly those facing similar challenges with software and image quality.
starstruck_
Hey!
So, I took images of NGC 7741 at school using CCD Soft. The field view looked exactly how I would expect when aligning to my galaxy, so I'm almost 100% my galaxy will show up once I stack my images ( I took a set of 20 with 1min exposure). I tried to check by stacking through PixInsight, however, there are unfortunately only around 3 stars that showed up on my images, PixInsight says you need 6 in order to stack.
Should I just go through with the assumption that my galaxy is there (although I can't see it) and start my data reduction and stack the images through IRAF?
Is there another way I can stack?
Astronomy news on Phys.org
I'm not familiar with your software, but there is other software that requires fewer stars to stack or let's you manually stack.
What is IRAF?
What is IRAF?
There’s software that uses fewer stars? Do you happen to know any?
we do our data reduction stuff through Xming/PuTty and it involves doing stuff in an IRAF and a Linux terminal.
I don’t really know how to explain it :// I’m in second year so don’t have extensive experience with data reduction
I use AIP4Win, but it's not free. CCDOPS will let you manually stack, but it's rather tedious for anything but a handful of images.
You can probably download a trial version of MaxIm DL Pro and use that.
Registax can use as few as 1.
IRAF is the pro Unix based software. It is very powerful but very old and command line driven.
BrushyCanyon said:
Try DeepSkyStacker (64 bit). Free and very versatile.
http://deepskystacker.free.fr/english/download.htm
BC
Yup …. I have used it for some years now … but I, like many, only do the stacking in DSS
we do the editing in lightroom, photoshop or whatever you other fav image processing app isDave
BC
This was helpful! Tried stacking, didn’t see the galaxy :(( there was a light leak when we were take photos of my galaxy(+11.25 mag) guess I’m using my friend’s images for data reduction, he didn’t have light leaks when he took the images of the galaxy later in the night:((
Although two professors told me that my field of view was perfectly fine and my galaxy SHOULD be there. Gosh darn it
Did you do any post processing? Can you upload a sample? Often, the signal needs a lot of amplification to be visible.
Do you use any plate solving programs, like Astrotortilla? This will let you precisely place your subs by matching your field with with referenced images.
in DSS ?
As @russ_watters hinted at, even after stacking in DSS, you will have to do significant post processing to bring out the object
Only with bright objects will you see anything of them after doing the stacking ( but before processing)
well that would probably destroy any faint objects and M11 or more is very faintDave
davenn said:
in DSS ?well that would probably destroy any faint objects and M11 or more is very faintDave
But this should show up after I do my reduction right? I’m hoping the light leak would somewhat be subtracted but idk. I’m worried now, definitely don’t want to have to go back and take images again.
if the light leak is on every frame, then no it won't be subtracted
if it is only on a couple of images, then remove those images from the ones to be stacked
Ah darn, looks like I’m retaking my images then ;-; (or not, my prof knows what happened and he said he’ll let me use my partner’s images for the reduction instead)
Do want my own set of images though, the galaxy is gorgeousEDIT: We did move the field of view as far away from the light leak as possible though (the field of view matched exactly so all of the galaxy is supposed to be in the darker area) guess I’m still screwed :((
First, are you properly 'stretching' your image? Images can sometimes be much darker than regular photos. In Pixinsight, use the 'nuke' button for auto screen transfer function.
Second, if you can't see the object after 'stretching' your image on a single frame, than stacking is not going to make it magically appear. Stacking will reduce noise.
Third, proper calibration images (bias, dark and flat) can help fix light leaks - to some extent.
The images I saved and worked with were black for some reason so I did stretch them, after stretching them, they looked like what I saw on the computer while using the CCD(my galaxy wasn’t there when I was taking images with the CCD - but my prof had said that we shouldn’t expect them to show up while we’re taking images, only after reducing)
But now there’s this amazing light leak I also need to deal with :))
Welcome to astrophotography and image processing. :wink:
PIxinsight: in Star alignment go to Star Detection and try these settings:- Detection scales try 8
Log Sensitivity try -3
All the rest in star detection leave at default
  • · Replies 39 ·
  • · Replies 226 ·
16K
  • · Replies 43 ·
12K
  • · Replies 93 ·
13K
