What Did I Do Wrong in My Quantum States Calculation?
The forum discussion centers on the calculation of quantum states for an electron confined in a one-dimensional box, initially using an incorrect confinement distance of 0.1Å instead of the correct 10Å. The formula used, n = (x_0*m*2*v)/h, where h is the Planck constant, was clarified to represent the number of cells in phase space. The correct calculation yields n = 27, aligning with the number of energy states for an infinite potential well. The discussion highlights the importance of precise parameters in quantum mechanics calculations.
  • Understanding of Quantum Mechanics concepts, specifically the particle in a box model.
  • Familiarity with phase space and its representation in quantum systems.
  • Knowledge of the Planck constant (h) and its role in quantum calculations.
  • Basic principles of Statistical Mechanics related to quantum states.
  • Study the derivation of the particle in a box model in Quantum Mechanics.
  • Learn about the implications of phase space in quantum systems and its mathematical representation.
  • Explore the relationship between quantum states and energy eigenstates in quantum mechanics.
  • Investigate the role of the Planck constant in various quantum mechanical calculations.
Students and professionals in physics, particularly those focusing on Quantum Mechanics and Statistical Mechanics, as well as researchers working on quantum state calculations and phase space analysis.
Saptarshi Sarkar
Consider an electron moving in 1D and confined within 0.1Å and it's speed not exceeding 10^7 m/s. The number of quantum states available to the electron is
a) 10^4
b) 56
c) 48
d) 27
n= x_0*p_0/h
I calculated the total area of phase space and divided it by the area of one cell i.e. h.
n = (x_0*m*2*v)/h
=> n = (0.1 x 10^-10 x 9.1 x 10^-31 x 2 x 10^7)/6.626 x 10^-34
=> n = 0.27
This answer doesn't match with any of the options. What did I do wrong?
Edit: The question was printed wrong, the confinement distance should be 10Å instead of 0.1. Answer comes out as 27.
Hi,
Can't understand what you are doing. Where does ##n= x_0\,p_0/h ## come from ? and how does it lead to ##n = x_0 \,m\,2\,v/h ## ? Does that mean ##p_0 = 2mv## ?
Do you know about particles confined to a box ?
BvU said:
Hi,
This question is from Statistical Mechanics
##n= x_0\,p_0/h ## is the number of cells of area h in the phase space (momentum vs position space) of the particle. It is the no of different possible cells the particle might be in.
##n = x_0 \,m\,2\,v/h ## was used as the momentum can be both positive and negetive, so the total area of phase space doubles.
I see. Wherever the Planck constant pops up, you are in the realm of quantum mechanics. I strongly suspect your ##n= x_0\,p_0/h## is not the right expression to use...
What do you think of the expressions in the link I gave ?
I know about the particle in a box problem in Quantum Mechanics. But this question is about the no of cells in the phase space which is totally a mathematical concept.
In classical systems the Phase Space is made up of points where the particle can be at and in quantum mechanical systems the phase space is divided into different microstates of equal area (volume in 3D) with the area ΔxΔp=h. So, total number of cells in 2D will be total area of phase space/h.
The question asks for quantum states.
Homework Statement:: Consider an electron moving in 1D and confined within 0.1Å and it's speed not exceeding 10^7 m/s. The number of quantum states available to the electron is
Quantum states is what my book is calling them. I am not sure if they are the same Quantum states as Quantum eigenstates.
When it says (see the section I've underlined):
What does that mean in quantum mechanics?
That the magnitude of the uncertainty in momentum is ##10^{-31+7}##?
That's not what I was thinking of. In QM the value of a dynamic quantity like speed only makes sense in the context of a measurement of that quantity - or a related quantity. In my opinion the question is poorly phrased since the electron could be in anyone of infinitly many superpositions of the allowed eigenstates.
The question is really asking for the number of possible measured values of the electron's speed below the given value. This is related to the energy eigenstates.
I was just going to suggest this. Whatever you did, you got the same answer as the number of energy states for an infinite potential well.
From the pdf it seems obvious that your approach was what was intended. So an error in the book answer is the most likely explanation. And @PeroK clinched it.
I was thinking about why the two answers should be same and I came up with an explanation
For a particle of mass m stuck in the x-axis from 0 to L and having maximum magnitude of momentum p
1) From phase space approach
No of microstates , ##m = \frac {L2p} {h}##
2) From considering an infinite square well
Maximum energy of particle
##E_{max} = \frac {p^2} {2m} = \frac {n_{max}^2π^2h^2} {8mπ^2L^2}##
=> ##n_{max} = \frac {2pL} {h}##
So, ##m = n_{max}##
  • · Replies 23 ·
