Nodal analysis with current source in s domain
Derill03
Okay i need to find expressions for v1 and v2 and I am using nodal analysis:
these are not the final the equations just initial equations by first look
I am good finding expression for v1,
(2/s)-(v1/1)-((v1-v2)/(2/s)) = 0
Where i am stuck is with the current source and 2 ohm res. in series
For v2,
((v1-v2)/(2/s))-(v2/2s)-(v2/2)-(5/s) = 0 this is my derivation that I am unsure of
the reason i think this is wrong for v2 is in my head i see instead of v2/2 - 5/s i see something like ((v2-v)/2)-(5/s)? where v is voltage between current source and res
Can anyone help me understand where I am right or wrong thanks
**BTW see attachment for circuit**
  • Circuit schematic in the s domain: a 2u(t) A current source feeds node v1, which connects through a 200 mF capacitor to node v2, with a 1 Ω resistor and a 2 H inductor to ground; a 2 Ω resistor in series with a 5u(t) A current source sits on the right branch.
For nodal analysis you're only concerned with summing the currents. The 2Ω resistor in series with the 5u(t) current source is not going to alter that current that it pulls from the V2 node. So ignore the resistor!
FYI, your entries for the capacitor impedance look a bit off. 1/(s*200 mF) should yield something like 5/s.
so would v2 be:
((v1-v2)/(5/s)) - v2/2s - 5/s?
my mistake on the cap transformation it is 5/s which is equal to 1/0.2s my bad
Derill03 said:
so would v2 be:
That looks fine :smile:
