Non-Central Forces in N-body Problems?
  • Thread starter Thread starter 0pt618
    Forces Orbit
In N-body problems, the net force on each body does not necessarily point to the center of mass of the system. This contrasts with 2-body systems, where forces typically direct towards the center of mass. Counterexamples exist, such as two equal charges that experience forces away from their common center of mass. Additionally, in a gravitational scenario with three equal masses, two masses close together can have a third mass far away, affecting the net forces. Thus, the behavior of forces in N-body systems can be complex and does not always align with the center of mass concept.
0pt618
For a 2-body system that is not under the influence of an external force, the forces on each body (assumed to be point particles) always point to the center of mass the 2-body system.
Does this still hold for general N-body problems, where N>2? Specifically, does the net force on each body point to the center of mass of the N-body system?
No.
Thanks A.T. - is there a classical counterexample?
As posed, your assertion isn`t even true for all 2 particle systems. Two equal charges can have net forces away from the common COM, not towards it. For gravity consider 3 equal masses, two of which are very close together, the thrid one very far away.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 35 ·
  • · Replies 84 ·
