Non-hydrogenated peanut oil becomes hydrogenated when heated?
  • Thread starter Thread starter Flatliner
    Oil
Heating non-hydrogenated peanut oil does not cause it to become hydrogenated; rather, the concern lies in the oxidation of double bonds when exposed to high temperatures and atmospheric oxygen. The discussion clarifies that hydrogen does not separate from peanut oil at high temperatures, and the process of hydrogenation requires specific conditions not met during typical frying. The potential for oil to become unhealthy arises from factors like rapid temperature changes and moisture introduction, rather than from the heating process itself.
  • Understanding of lipid chemistry and fatty acid structures
  • Knowledge of oxidation processes in cooking oils
  • Familiarity with the concept of hydrogenation in food science
  • Basic principles of thermodynamics related to frying temperatures
  • Research the process of lipid oxidation and its effects on health
  • Learn about the industrial hydrogenation process known as "sparging"
  • Investigate the role of moisture in frying and its impact on oil quality
  • Explore the chemistry of triglycerides and their reactions during cooking
Food scientists, culinary professionals, health-conscious cooks, and anyone interested in the chemistry of cooking oils and their health implications.
Flatliner
Can't find a reliable source on the internet for the answer to this question. Some claim that heating peanut oil at high enough temps to fry food causes the oil to become partially hydrogenated therefore causing it to become an "unhealthy" oil. Is this true?
Biology news on Phys.org
That's just a guess on my side, but I don't see how it can become hydrogenated when there is no hydrogen. However, with plenty of atmospheric oxygen around, oxidation of the double bonds (no matter what the exact products are) seems quite possible.
Is there hydrogen already naturally in peanut oil that separates from molecules at high temps and hydrogenates the oil?
That's unhealthy?
No, there is a hydrogen, but it doesn't separate.
That's unhealthy?
Yes, that's more or less how fats get rancid.
The claim I've heard isn't that heating it to high temperatures does it, but the rapid temperature drop along with introduction of water and then reheating when you drop whatever frozen food you're frying into it. I'm also not sure if this is a legitimate claim or an internet myth, but perhaps with those additional details, Borek will have more insight if it's possible.
The way Moonbear heard it seems more reasonable, since theoretically: E + 2H_2 O = 2H_2 + O_2
where E is energy.
But then there's at least two important questions to ask:
1) how much Energy is required; does a fryer produce it?
2) how much water is required to produce enough hydrogen to saturate the food (in a dilution of peanut oil?) to a significant level?
Hi Moonie :smile:
where E is energy.
No way, thermal decomposition of water requires insane temperatures - over 2000 deg C for a single digit percent decomposition.
On the other hand, water doesn't have to decompose first, such thing could be a several step process, yielding a similar final result. But I find it highly unlikely.
This is the simplest part. Assuming oil is a trigliceryde with three monounsaturated fatty acids, each 18 carbons long, its molar mass is 879 g/mol. There are three double bonds, so in theory it can react with up to three moles of water. In other words - you would need 56 g of water to fully saturate 879 g of oil. That's not exact, as oil is not just a single trigliceryde, but IMHO it is a quite good estimate
I can be wrong, but I don't like this explanation. Water can be added to the double bond, that's a well known reaction, but it doesn't yield alkane and oxygen - it yields secondary alcohol. Besides, water has much better place to attack - it can hydrolise the ester, yielding glycerin and fatty acid itself. The latter reaction is catalyzed by bases and acids, so it won't be very fast in the fryer, but seems much more likely to me.
I am now hungry for beer battered halibut
The partial or complete hydrogenation of unsaturated vegetable oils is an industrial process called "sparging". It involves treating the oil under high temperature and pressure in the presence of a catalyst such as powered nickle together with molecular hydrogen.
http://www.tutorvista.com/science/vegetable-oil-saturated
most store-bought peanut butter already has hydrogenated oil added so that it doesn't separate. natural peanut butter will separate with a layer of light oil on top if you leave it out, meaning you've either got to stir it with a butter knife regularly or leave it in the fridge.
so, for most of us, worrying about cooking temps is a bit like trying to shut the barn door after the horse has escaped.
12K
  • · Replies 60 ·
13K
