Non linear field of a long bar magnet
  • Context: Graduate
  • Thread starter Thread starter shustrng
    Field Linear Magnet
The discussion focuses on reducing the "end effect" observed in a long bar magnet, specifically a 0.5 cm square bar magnet measuring 5 inches in length. The end effect results in a stronger magnetic attraction at the ends of the magnet, causing objects like washers to be repelled when placed near the ends. The participants explore the phenomenon where magnetic flux lines exit the magnet before reaching the pole, leading to dual north pole interactions that cause repulsion. Suggestions for dampening this effect are sought to achieve a more uniform magnetic field along the entire length of the magnet.
  • Understanding of magnetic field theory
  • Familiarity with bar magnet properties
  • Knowledge of magnetic flux lines
  • Basic principles of magnetization
  • Research methods to mitigate end effects in bar magnets
  • Explore magnetic field visualization techniques
  • Investigate materials that can modify magnetic fields
  • Learn about magnetic circuit design principles
Physicists, engineers, and hobbyists interested in magnetism, particularly those looking to optimize the performance of bar magnets in practical applications.
shustrng
How can the "end effect " be reduced on a long Bar magnet where the (for example) North pole is along the length of the top side. For example a 0.5 cm square bar say 5" long is stuck (South) onto a metal backing. The center length of 4" has a linear field effect but the ends have a bloom presumably as the N/S pole fields overlap. For example a small washer can be placed anywhere along the middle (top side) and will stay where placed, but when slid to the end, and released, it jumps back a cm away from the end? Basically, this non-linear field is stronger attracting at these ends. It is desired to reduce this end effect.
If I understand your experimental observations, some of the magnetic flux lines in the north direction exit the magnet near the north pole, but before they reach the pole. As a result, a thin piece of iron placed on top of the magnet near the north pole will also become magnetized in the northerly direction. The result is you then have two north poles right next to each other and they will repel. Alternatively, if the piece of iron were introduced adjacent to the pole (on the endface), the magnetization would be such that the south pole end of the piece of iron would be adjacent to the north pole of the magnet, and it would stick to it. ## \\ ## I think I interpreted your observations correctly, but I don't know how to reduce the effect.
Thanks Charles. Well the sliding washer is just a simple trick to show the end effect but I hope to have suggestions to try to dampen/shorten this effect and be able to use the entire length as a more linear field for other uses.
10K
13K
  • · Replies 18 ·
