Non-linear ODE, plane-polar coordinates.
6 replies · 2K views
spitz
I have:
[itex]\dot{x}=4x+y-x(x^2+y^2)[/itex]
[itex]\dot{y}=4y-x-y(x^2+y^2)[/itex]
And I need to find [itex]\dot{r}[/itex] and [itex]\dot{\theta}[/itex]
2. The attempt at a solution
I got as far as:
[itex]\dot{x}=r(\text{sin}(\theta)-\text{cos}(\theta)(r^2-4))[/itex]
[itex]\dot{y}=r(-\text{sin}(\theta)(r^2-4)-\text{cos}(\theta))[/itex]
How do I go from here to [itex]\dot{r}[/itex] and [itex]\dot{\theta}[/itex] ?
spitz said:
I have:
I got as far as:
For the left sides of these last two equations you have ##x = r\cos\theta,\ y = r\sin\theta## to work with. Remembering that everything is a function of ##t##, you can caculate ##\dot x## and ##\dot y## by differentiating those, using the chain rule.
Ok, so I have:
[itex]\dot{r}\cos(\theta)-r\sin(\theta)\, \dot{\theta}=r(\sin(\theta)-\cos(\theta)(r^2-4))[/itex]
[itex]\dot{r}\sin(\theta)+r\cos(\theta)\dot\theta=r(-\sin(\theta)(r^2-4)-\cos(\theta))[/itex]
Is there a "non-tedious" way of solving this?
I can't speak for what you would consider tedious but the standard method would be to multiply the first equation by [itex]cos(\theta)[/itex], the second equation by [itex]sin(\theta)[/itex], and add the two equations. Then turn around and multiply the first equation by [itex]sin(\theta)[/itex], the second equation by [itex]cos(\theta)[/itex], then subtract.
Have I got this second part right?
[itex]-r\sin^2(\theta)\dot{\theta}-r\cos^2(\theta)\dot{\theta}=r(sin^2(\theta)+cos^2(\theta))[/itex]
[itex]-r(sin^2(\theta)+cos^2(\theta))\dot{\theta}=r[/itex]
[itex]\dot{\theta}=-1[/itex]
You mean, I presume, [itex]\dot{r}[/itex], not r, on the left of both of those two equations. Now, how did you get "-1" on the right of the last equation? It looks to me like you have r on the right of both first two equations. Isn't r- r= 0?
[itex]\sin\theta\dot{x}-cos\theta\dot{y}:[/itex]
[itex]\dot{r}\sin\theta\cos\theta-r\sin^2\theta\dot{\theta}-\dot{r}\sin\theta\cos\theta-r\cos^2\theta\dot{\theta}=r[\sin^2\theta+\cos^2\theta+(sin\theta\cos\theta-\sin\theta\cos\theta)(4-r^3)][/itex]
[itex]-r(\sin^2 \theta+\cos^2 \theta)\dot{\theta}=r(\sin^2 \theta+\cos^2 \theta)[/itex]
[itex]-r\dot{\theta}=r[/itex]
[itex]\dot{\theta}=\frac{r}{-r}=-1[/itex]
