How Is Non s-Wave Superconductivity Gap Parameter Chosen?
  • Thread starter Thread starter nbo10
    Superconductivity
nbo10
In BCS you make the assumption that the effective electron-electron interaction is constant within a small shell around the fermi surface and zero otherwise. From this you get a constant spherical gap.
In non s-wave SC there is a specific form for the gap ie, \Delta_0 = [ \cos (k_x a) - \cos (k_y a)]. I know that you can calculate the gap parameter using group theory and the underlying symmetry of the crystal lattice. But is there a way to choose an arbitary form for k \cdot k^\prime, self consistently solve the gap equation and arrive at a d-wave gap or any other non s-wave gap?
How do you choose the effective electron-electron interaction? Is it based on the atomic orbitals that are believed to be responsible for SC? I've done a few searches and all I find is a assumption for the form of the gap. Thanks
This isn't an easy question to answer because this is still something being worked on. Something like the t-J method using mean-field approximation can drop the d-wave symmetry onto your lap (this assertion is still controversial). In many instances, the symmetry is inserted by hand because that is the product of experimental observation. There's a persuasive reason why this is having that d-wave symmetry - the valence shell of the Cu in the CuO plane where superconductivity is thought to reside. The transition metals have d-orbitals valence shell.
Note that for the Ruthenates, you have a p-wave symmetry for the pair.
Zz.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
19K
