Nonlinear spring energy problem
The discussion focuses on calculating the change in potential energy (U) of a nonlinear spring described by the force equation F=40x-6x^2 when stretched 2 meters. The initial calculation of U using the force yielded 56J, which was incorrect. The correct approach involves integrating the force function to find U, resulting in a change of potential energy of -64J, indicating that 64J of work is done when stretching the spring.
  • Understanding of nonlinear spring mechanics
  • Familiarity with calculus, specifically integration
  • Knowledge of potential energy equations
  • Basic physics concepts related to force and work
  • Study the integration of force functions in physics
  • Learn about potential energy calculations for nonlinear springs
  • Explore the relationship between force, work, and energy
  • Review the principles of Hooke's Law and its limitations
Students studying physics, particularly those focusing on mechanics and energy concepts, as well as educators looking for examples of nonlinear spring behavior and energy calculations.
lzh
The stretch of a nonlinear spring by an amount x requires a force F given by:
F=40x-6x^2
where F is in Newtons and x is in meters.
What is the change in potential energy U when the spring is stretched 2m from its equilibrium position?
U=.5kx^2
= .5(kx)x
F=kx
F=40(2)-6(2)^2=80-24=56N
U=.5(56N)(2)=56J
Thats what I thought would work, but 56J is no the correct answer. What am I doing wrong?
F=-dU/dx
use this
So it'd be:
56N(2m)=-dU
dU=-112?
Am I not getting this?
F=40x-6x^2
U=.5kx^2
= .5(kx)x
F=kx
U=.5(56N)(2)=56J
The trick here is to recognize that F=40x-6x^2 which is not the same as F=kx.
Now U(x) = \int^x_0\,F(x) dx\,=\,\int^x_0\,kx\,dx
http://hyperphysics.phy-astr.gsu.edu/hbase/pespr.html#pe2
http://hyperphysics.phy-astr.gsu.edu/hbase/pegrav.html#pe
Oh, I see!
Thanks, I got it!
f=-dU/dx
integrating both sides
20x^2 -2x^3=-U
put x=2
U=-64J
change would be 64...and work done would be 64 J
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 18 ·
