Normal component of the acceleration
14 replies · 4K views
Sheen91
Given y[tex]^{2}[/tex] = 8x[tex]^{3}[/tex] + 8x
where x and y are in metres, and y is positive
What is the normal component of the acceleration
When x = 4m, x = 7m/s, x = 2m/s[tex]^{2}[/tex]
Note : Wasn't sure if it was Calc or Physics, but I was leaning toward Calc, as it is basically Algebra to solve for the answer.
Not sure
I understand that "x = 4m, x = 7m/s, x = 2m/s[tex]^{2}[/tex]" is just "y[tex]^{2}[/tex] = 8x[tex]^{3}[/tex] + 8x" getting differentiated for each part, first of which doesn't need it.
y[tex]^{2}[/tex] = 8x[tex]^{3}[/tex] + 8x => y = ([tex]\sqrt{8x^3 + 8x}[/tex])
I am just a little lost at "What is the normal component of the acceleration"
Any and all help is greatly appreciated.
Thanks
These should probably be "... when x = 4m, dx/dt = 7 m/sec, and d^2x/dt^2 = 2m/sec^2. You can't have x being equal to three different quantities with three different units.
Not sure
Are you sure that you are giving us the exact wording of this problem? It doesn't make much sense to me as you have written it.
Thanks
If this is not a trajectory in the plane, then the problem makes no sense- there is no "normal component". If it is a trajectory then you need to find the acceleration as the vector [itex](d^2x/dt^2}\vec{i}+ (d^2y/dt^2)\vec{j}[/itex]. Of course, to do that, you have to know the dependence of x and y on t.
Knowing that [itex]y^2= 8x^3+ 8x[/itex] tells you that [itex]2y(dy/dt)= (24x^2+ 8)(dx/dt)[/itex] but uyou still need to know or be able to calculate either dy/dt or dx/dt.
I agree with Mark44- please give the exact wording of the problem. "When x = 4m, x = 7m/s, x = 2m/s2" is impossible.
I came across the same question. Sheen has typed the entire question. Only mistake being the repeated x. Which was meant to be x, x' and x''.
I derived the equation twice and subbed in the given x values as i derived to get the corresponding y values. i.e. i solved for y, y' and y". Is this right?
If this is right i still get stuck on how to find the normal component.
***Post removed***
y² = 8x³ + 8x
2y dy/dt = (24x² + 8) dx/dt
Velocity = sqrt ( (dx/dt)² + (dy/dt)² )
Acceleration = sqrt ( (d²x/dt²)² + (d²y/dt²)² ) = ? :S (not sure)
2 d²y/dt² = 48x d²x/dt²
d²y/dt² = 24x d²x/dt²
Therefore:
Acceleration = sqrt ( (d²x/dt²)² + (d²y/dt²)² ) = sqrt( (d²x/dt²)² + (24x . d²x/dt²)² ) = sqrt ( 2² + (24 . 4 . 2)²) = sqrt ( 36868 ) = 192.01 m/s/s
Which doesn't seem right. :S
Can someone look through and see if I did anything wrong. Thank you
PS: I need to find the normal component of the acceleration, so I have yet to start that
Sorry I don't understand how, do I use the product rule in that??
Thanks for all the help so far vela, I really appreciate it
EDIT:
uhmm ohh wait
dy/dx = (dy/dt) / (dx/dt)
dy/dx = (dy/dt) / (dx/dt) = (24x² + 8) / 2y
d²y/dx² = ( (48x . 2y) - 2(24x² + 8)dy/dx ) / 4y²
I am a little lost.
vela said:
This is good. Come up with numerical answers for what y and y' equal given the information you have about x and x'.
y = sqrt (8x³ + 8x) = sqrt (8.4³ + 8.4) = sqrt (544) = 23.324
y' = (24x² + 8) x' / 2y = 58.82
now what?
I am unsure on how to find the "Normal component of the Acceleration"
Vela can you let me know what to do step by step, rather than just one step at a time. I would really apreciate that.
I also got the numerical values of y and y', and am once again stuck.
Also how do I use the product rule on : 2y dy/dt = (24x² + 8) dx/dt
Have never been taught.
I think I got it:
Product rule
(2 dy/dt) . dy/dt + d²y/dt² = (48x . dx/dt) + ( (24x² + 8) . d²x/dt²)
so that means:
d²y/dt² = (48x . dx/dt) + ( (24x² + 8) . d²x/dt²) - (2 dy/dt) . dy/dt
d²y/dt² = -4791.58
That seems very wrong.
Also after you get d²y/dt² and d²x/dt², what do you do? How do you find the normal component?
Sheen91 said:
I think I got it:
Product rule
You forgot the 2y in front of y''. The RHS looks okay.
You have the two vectors a=axx+ayy and v=vxx+vyy. What you want to do is resolve a into components parallel and perpendicular to v. So how do you find the component of a parallel to v? Hint: Use the dot product.
Drawing a vector diagram for this question helps a lot. It helped me solve it =]
