Normal force of a body over a circular bridge
The discussion revolves around the normal force experienced by a body moving over convex and concave bridges in vertical circular motion. Participants explore the relationships between forces acting on the body, including gravity and centripetal force, and seek to understand why the normal force varies at different points in the motion.
  • Some participants express confusion about why the normal force is least at the top of a vertical circular motion and highest at the bottom.
  • Others suggest drawing free body diagrams (FBD) to analyze the forces acting on the body at the top and bottom of the curves, emphasizing the direction of these forces.
  • It is noted that at the top of a convex bridge, the normal force acts upwards while gravity and centripetal force act downwards, whereas at the bottom of a concave bridge, the normal force acts upwards along with centripetal force, and gravity acts downwards.
  • Some participants clarify that "centripetal" and "centrifugal" are not types of forces but rather directions in which forces act.
  • A participant mentions that the sum of the normal and gravitational forces must equal mv²/r, referencing Newton's 2nd Law, and relates this to scenarios like roller coasters.
  • There is a discussion about the implications of speed at different points in the motion and how energy conservation principles apply.
Participants do not reach a consensus on the explanations for the variations in normal force. Multiple competing views and interpretations of the forces involved remain present throughout the discussion.
Participants reference the need for free body diagrams and Newton's 2nd Law but do not provide a complete resolution to the mathematical relationships or assumptions involved in the analysis of forces.
Shashwat02
TL;DR
Hi! Can somebody please explain me the concept of normal force over convex and concave bridge?
I am not able to understand why normal force on top in a vertical circular motion the least.
Also please help me with normal force of a body over convex and concave bridges.
Why do we get these equations:
N=mg-mv2/r (convex bridge)
N=mg+mv2/r (concave bridge)
Are you familiar with centripetal acceleration, free body diagrams, and Newton's 2nd law? At the top of the circle (convex curve), draw a free body diagram of the forces acting on the body, with the body in contact with the surface on the outside of the circle. Do the same at the bottom of the circle (concave curve), with the body in contact with the surface on the inside of the circle. In each case, what is the direction of the two forces that act on the body?
The normal force acts upwards and force due to gravity and centripetal force act downward in convex bridge.
In concave bridge normal force acts upwards along with centripetal force and force due to gravity acts downwards.
Please explain me why normal force at topmost point in vertical circular motion is least and highest at bottom.
How are the three forces you named related quantitatively? Have you looked at Newton's 2nd Law?
Consider FBD of a vehicle on the top of a convex and concave bridge.
Please realize that "centripetal" and "centrifugal" are not types of forces. They are directions in which a force can act: toward the center or away from the center.
On a surface that is concave, the normal force from the surface against an object is a centripetal force. On a convex surface, the normal force from the surface against an object is a centrifugal force.
[Confusingly, the term "centrifugal" is often applied to a very specific force -- the apparent outward inertial force associated with the adoption of a rotating frame of reference]
Please note that in your example problem, the body rides above (on top of) the convex surface and above the concave surface, and your direction of the normal and weight forces are correct for each case. The sum of these two forces must equal mv^2/r, per Newton’s 2nd Law. This would be an example of a typical roller coaster ride. The coaster can’t be going too fast at the top of the convex surface or else it would fly off the rail (without safety features).
Now a “loop-the-loop” roller coaster, where you ride on the inside of the loop, upside down when on top, is a bit different. At the top, gravity force still acts down, but which way does the normal force act? You can’t be going too slow on top, or else you’d fall off the track(without safety features).
In both cases, the speed is greater at the bottom because of conservation of energy principle, with which hopefully you are familiar.
