BiotFartLaw
- Messages
- 4
- Reaction score
A bar with mass m and length l is attached at one end to a string (also length l) and is swinging back and forth. Find the normal modes of oscillation.
L=T-U, and the Lagrange-euler equation, I=(1/12)ml^2
So my idea is this. Use the two angles [itex]\theta[/itex] (angle of string from the vertical) and [itex]\phi[/itex] (angle of the bar from the vertical) as the generalized coordinates and set up a Lagrangian to get two (probably coupled) differential equations. THen I'm guessing two different eigenfrequencies will pop out when I solve them.
My problem is that I'm not sure what the (translational) kinetic energy is. (The rotational would just be I*ω^2 and this ω^2 would, in the end, give me the two frequencies [?]) I've tried finding [itex]\dot{x}[/itex] and [itex]dot{y}[/itex] using sines and cosines of the angles, but when I do (and I make appropriate approximations) I'm left with no [itex]dot{\theta}[/itex] or [itex]dot{\phi}[/itex]terms which doesn't seem right.
But I'm also not sure if it's as simple as [itex]T=ml^2(dot{\theta}+dot{phi})[/itex].
Thanks
