Normal tangential co-ordinates(ut,un)
  • Thread starter Thread starter princejan7
    Normal
The discussion focuses on calculating the radius of curvature (p) of a jet's path while it is in a dive, given a force of 800 lb acting on a pilot weighing 180 lb and a speed of 850 mph. The relevant equation used is the centripetal acceleration formula, an = (v^2)/p, where an represents the acceleration normal to the flight path. The participants explore the relationship between forces acting on the pilot and the necessary components of acceleration to solve for unknown forces in a circular motion context.
  • Understanding of centripetal acceleration and its formula
  • Familiarity with normal-tangential coordinate systems
  • Basic knowledge of forces acting on objects in circular motion
  • Proficiency in solving simultaneous equations
  • Study the application of centripetal force in circular motion problems
  • Learn about polar coordinate systems and their advantages over normal-tangential systems
  • Explore the derivation and application of the equation a = (dv/dt)at + ((v^2)/p)an
  • Investigate the dynamics of forces acting on pilots during aerial maneuvers
Aerospace engineers, physics students, and anyone interested in the dynamics of forces in aviation and circular motion analysis.
princejan7
A jet is coming out of a dive and a sensor in the pilots seat measures a force of 800lb for a pilot whose weight is 180lb. If the jet's instruments indicate that the plane is traveling at 850mph, determine the radius of curvature, p, of the plane's path at this instant
a= (dv/dt)at + ((v^2)/p)an
So I think this involves the component of acceleration in the direction perpendicular to the
flights path at that point?
so an=(v^2)/p
But I don't know what an is at that point?Also, for what kind of problems should the polar coordinate system be used over the normal-tangential co-ordinate system?
http://postimg.org/image/45lhhjrqp/
same as above question
So at B, I think I can find the component of acceleration perpendicular to the path(which will point towards the center in this case?) using (v^2)/p and then use that to find the resultant force in the same direction using RFn=m(an)
But I don't know what to do next. Is that enough information to solve simultaneously for both the unknown forces?
The pilot's seat exerts a force on him to (i) exactly balance his weight, and (ii) to force him to follow a circular path. At the bottom of the plane's loop, what is the direction in which each of these forces acts?
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 35 ·
  • · Replies 35 ·
  • · Replies 35 ·
  • · Replies 35 ·
