Normalizing wavefunction of (x^2)e^(-x^2)?
  • Thread starter Thread starter lonewolf219
    Wavefunction
The discussion focuses on normalizing the wavefunction ψ(x,t)=Axe^{-cx^2}e^{-iωt} by integrating the product ψ*ψ. Participants express confusion about integrating the term involving x^2 and e^{-2cx^2}, noting that this topic wasn't covered in class. They discuss techniques for evaluating Gaussian integrals, including differentiation with respect to parameters and changing to polar coordinates. The conversation highlights the importance of understanding these mathematical methods for physics applications, particularly in statistical mechanics. Ultimately, participants clarify the relationship between the integrals and their derivatives to solve the problem.
lonewolf219
1=∫ψ*ψdx
1=\intA^{2}x^{2}e^{-2cx^2}
I think I multiplied ψ*ψ correctly... I'm surprised a little that there is an x^2 with this problem. We have not discussed these integrals in class. I watched a video on how to integrate e^{-x^2}, but don't know what to do with the product x^2 and e^(-2cx^2)
Did you take statistical mechanics ? You learn about integrating gaussians there. If not, then at least a course in mathematical methods of physics should have explained you this.
Anyways, think I(c) = int_R exp(-cx2) dx. Compute it then differentiate the result wrt c. (c is a parameter).
I'll give you a hint.
I presume you know that: \int_{- \infty}^{+\infty} e^{-\lambda x^2}dx = \sqrt{\pi/ \lambda}. Consider the function:
I(\lambda )=\int_{- \infty}^{+\infty}e^{-\lambda x^2}dx
Then:
\frac{d}{d\lambda }I(\lambda )=-\int_{- \infty}^{+\infty}x^2e^{-\lambda x^2}dx
Likes 1 person
You could also integrate by parts.
Thanks for the help, guys! Didn't take statistical mechanics, unfortunately...
Does this mean that the derivative of \sqrt{\frac{\pi}{\lambda}} is my answer?
vela is correct, but kostas230's trick is one of the most beautiful in mathematics and one of the most important in physics. The technique is referred to as using a "generating functional."
I don't know if you ever had to evaluate the Gaussian integral, but here's an elegant way to do it. Consider the integral:
I= \int_{-\infty}^{+\infty}\int_{-\infty}^{+\infty} e^{-(x^2+y^2)}dxdy
By changing from cartesian coordinates to polar coordinates, the integral above becomes:
I= \int_{0}^{+\infty}\int_{0}^{2\pi}re^{-r^2}drd\theta
I trust that you are able to evaluate the integral. Can you find the gaussian integral I'=\int_{-\infty}^{+\infty}e^{-x^2}dx using the above results? ;)
Thanks kostas230, appreciate your help:smile:... The result should be in the form of a Hermite polynomial, is that correct? I think the derivative of re^{-r^2} is
e^{-r^2}(1-2r^{2})
Not quite sure what to do next
No, I said: compute the integral, not find the derivative of the integrated function
If you are asking me to find the integral of re^{-r^2}drd\theta from 0\leqr\leq\infty and 0\leq\theta\leq2\pi I believe it is \pi. And then the integral with a coefficient λ in the power would be \frac{\pi}{\lambda}
That is right, and it allows you to find the value of the original Gaussian integral, if you find the relation between that and the formula kostas230 used.
Thank you, mfb.
So is it that I^{2}= \frac{\pi}{\lambda}
So the derivative of \frac{\pi}{\lambda} is -\frac{\pi}{\lambda^2}?
Since the derivative would be 2I for I^{2}, should I divide -\frac{\pi}{\lambda^2} by 2, so that I=-\frac{\pi}{2\lambda^2} ?
Although A is a positive value.. would the negative sign in front of kostas' integral cancel this one, so that I =\frac{\pi}{2\lambda^2} ?
I think you are mixing two different approaches here.
My first post was on an algorithmic process in finding integrals of the form: I_n=\int_{-\infty}^{+\infty}x^n e^{-\lambda x^2}dx presuming that you know the integral I_0=\int_{-\infty}^{+\infty}e^{-\lambda x^2}dx=\sqrt{\pi}. My other posts where to show you a way to compute the integral \int_{-\infty}^{+\infty}e^{-\lambda x^2}dx=\sqrt{\pi}.
