Not really a equation? finding friction
  • Level: High School
  • Thread starter physicsgurl12
    Friction
31 replies · 5K views · last reply
physicsgurl12
how would you find the coefficient of friction on a car using a stopwatch??
i was trying to use this webite ( i didnt really help explain anything) to help it says you should get about .9 but i really want to know how.
http://regentsprep.org/regents/physics/phys01/friction/default.htm
Depends, whether it is static friction on kinetic friction
I don't see how a stopwatch would help.
While the wheels are not slipping (which is usual for a car), the acceleration times mass of the car must be provided by the friction force between the tyres and the road. We have a limit for the max force provided by static friction, which is [itex]f_{max} = \mu_s F_N[/itex], where [itex]F_N[/itex] is the normal force (equal to the weight of the car usually). So if the acceleration times mass of the car breaks this limit, the force of static friction is no longer enough to keep the tyres from slipping.
So to measure the coefficient of static friction, you could measure the maximum of 'mass times deceleration' without the tyres slipping, and divide by the weight of the car.
Of course, there will be much more accurate ways of measuring static friction. But this is one way that any tom, dick or harry could do. (Although I don't advise wearing out your tyres by doing this experiment).
Take the time it takes for the car to stop from an initial speed with brakes maximally engaged.
[tex]\mu_k = {v \over g \cdot t}[/tex]
(This measures the coefficient of kinetic friction.)
Oh, I see. Yes, you could use a stopwatch to measure the coefficient of kinetic friction.
An estimate of the static coefficient of friction could be made when braking maximally without locking the wheels.
physicsgurl12 said:
why do you find kinetic and not static??
Kinetic friction is when the wheels slip on the pavement.
Static friction is when the wheels do not slip.
The maximum static friction is higher than the kinetic friction.
Yes. There are two equations.
1) if the wheels are not slipping: [itex]f_{max}=\mu_s F_N[/itex]
2) if the wheels are slipping: [itex]f=\mu_k F_N[/itex]
For the wheels to not slip, the horizontal force on the entire car must be provided by the friction force. In other words, as long as [tex]f_{max} \geq m \frac{d^2x}{dt^2}[/tex]
then the wheels will not slip. the horizontal acceleration will be due to braking. So as long as you don't brake too hard, the wheels won't slip!
You will know because suddenly you start gliding, and it makes you feel out of control! Assuming you do not have an anti-blocking-system (ABS) of course.
haha thanks! that helps a lot.
would you use cruise control for you initial velocity??
That's probably best to start from an accurate initial speed.
Or at least from a reproducible initial speed.
If you drive 10 miles per hour and lock the wheels, you're guaranteed to stop within 2 meters.
That should be safe enough.
After that you can try it a little faster to be able to make a better time measurement.
Btw, you can also use the stopping distance to calculate the coefficient of kinetic friction.
[tex]\mu_k = {v^2 \over 2 \cdot g \cdot x}[/tex]
yes. I am actually doing it. i have to. its a project.
Sounds like fun! :smile:
When will you do it?
after thanksgiving break. so the week after next.
is this going to be an actual person sitting inside a real car? Isn't there a danger of serious neck injuries? Because you need to brake pretty hard to make the wheels slip?!
Better check your health insurance covers this kind of thing!
I think you're exagerating here.
Where I live it is required to do an emergency brake test when you get your driver's license.
It can happen that the wheels lock.
The maximum acceleration is "only" less than 1G.
This is very different from being unexpectedly hit from behind with 30+ miles per hour.
Hmm, the jerk is probably more important. The change in acceleration would be roughly 1G, but what time does this change occur over? I don't know the answer, and I don't know what is a safe level.
You're probably right though, since I don't think people often get whiplash from simply braking. I was just thinking that she would probably need to do the experiment at least a dozen times to get sufficient repeats, and that sounds painful.
I believe jerk it not the most relevant - but impulse versus time.
Basically this is simply acceleration.
If the impulse is spread over a longer time (seat belts, airbag), the acceleration is less.
The neck can only withstand a limited acceleration, but certainly more than 1G, especially if you expect it.
Acceleration is not important. Think of astronauts in training. They are subjected to high accelerations gradually, and the only thing that happens to them is that they eventually lose consciousness. They don't damage their necks. It is the higher derivatives that cause neck damage.
In other words, if neck damage were to be caused by a roughly constant acceleration, it would need to be really great.
Let's make it a combination of jerk and acceleration.
An (unexpected) quick change of acceleration can break your neck.
A high enough acceleration of the car can also break your neck.
Both do not occur when making an emergency stop.
