Novice question about Relays, Capacitors, and Diodes
The discussion revolves around the use of relays, specifically the TQ2SA-1.5V relay, and the associated components such as diodes, capacitors, and resistors in circuit design. Participants explore the protection mechanisms for the relay against back EMF and arcing at the contacts, as well as the appropriateness of component specifications for low-load applications.
  • Homework-related
  • One participant inquires about the necessity and adequacy of using a 1N4001 diode to protect the relay from back EMF, suggesting that its 50V capacity is sufficient.
  • Another participant agrees that the 1N4001 diode is adequate, emphasizing that the back EMF is dependent on the coil's characteristics and that the diode's reverse voltage rating is more relevant to the battery voltage than the relay's operation.
  • Concerns are raised about the potential for arcing at the relay contacts and the suggestion to use a capacitor and resistor in parallel to mitigate this issue, with specific values proposed for different load conditions.
  • One participant expresses skepticism about the necessity of the proposed capacitor and resistor values, suggesting that for low loads, simpler components might suffice.
  • Questions arise regarding the significance of inductance in the circuit and its relationship to back EMF, with a request for further reading on the topic.
  • A participant seeks clarification on calculating back EMF and references a formula related to capacitive current, questioning its applicability.
  • Concerns are raised about using an LED for voltage drop in the circuit, with warnings about potential issues related to battery voltage fluctuations.
  • Discussion includes a participant's clarification on the power source and current draw, questioning how battery capacity and circuit resistance interact.
Participants express differing views on the necessity of certain protective components for low-load applications, with some suggesting overdesign while others advocate for caution. The discussion remains unresolved regarding the optimal approach to component selection and the implications of inductance and back EMF calculations.
Participants mention various assumptions about load conditions, component specifications, and circuit behavior, but these assumptions are not universally agreed upon. The discussion reflects a range of perspectives on the design considerations for the relay circuit.
shushi
TL;DR
How to determine specific capacitors and diodes in order to minimize back emfs and arcing of opening contacts.
Hello,
In regards to this relay, TQ2SA-1.5V Panasonic 2 Form C AS Single side stable, 1.5VDC 2A DPDT NON-LATCHING SMD Relay
https://www.mouser.com/ProductDetail/769-TQ2SA-1.5V
PDF 1 of Relay
PDF 2 of Relay (specifically pages 5-6) is attached at the bottom as a pdf file.
I was previously told that I would need to wire a IN4001 diode which have a 50VDC blocking capacity, in parallel to the coil pins of this relay which could produce a back emf surge of up to 50VDC, which was more than enough to protect this specific circuit.
https://www.engineersgarage.com/electronic-components/1n4001-diode
PDF of 1N4001-Diode
I know basic electronics and ohms law theory, but I'm still a bit of a novice to when it comes with electronics, but is this true? Is a IN4001 diode more than enough to protect this circuit?
In the PDF, it says this about the coil and contact electrical characteristics,
>Electrical characteristics
>>Breakdown voltage
>>(Initial)
>>>Between open contacts 1,000 Vrms for 1 min. (Detection current: 10 mA)
>>>Between contact and coil 1,500 Vrms for 1 min. (Detection current: 10 mA)
>>>Between contact sets 1,500 Vrms for 1 min. (Detection current: 10 mA)
>>Surge breakdown
>>voltage (Initial)
>>>Between open contacts 1,500 V (10×160µs) (FCC Part 68)
>>>Between contacts and coil 2,500 V (2×10µs) (Bellcore)
but I'm not sure how to translate this as useful data when looking at the capacities of the IN4001 diode.I was also told that I needed to protect the contact ends of the relay since when they open up, they tend to create an arc that can wear out and damage the relay's performance. I was reading on another forum that in order to minimize this damage that I needed to wire a capacitor and a resistor in parallel to those contact ends, which they provided a "No Math" approach to figuring out the capacity and type of capacitors and resistors that I needed, which was the following method,
for the farad value of the capacitor,
0.5 to 1 µF per switching current (or per 1 Amp)
and for the voltage of the capacitor,
Use a capacitor with a dielectric strength between 200 and 300 V
and for the resistance value of the Resistor,
0.5 to 1 O per switching voltage (or per 1 Volt)
Based on my schematics, are 0.04µF 300VDC capacitor + 5 Ohm 5 Watt resistor approprate for a circuit that has total of 22mA and 5VDC, and a 0.02µF 300VDC capacitor + 5 Ohm 5 Watt resistor for a circuit that has total of 40mA and 5VDC?
Sorry for asking a beginner's question, but I'm still trying to learn more about circuitry and electrical engineering. Thank you for your time!
  • relay.pdf
    relay.pdf
:welcome:
Serious case of overdesign. Those 5W resistors will be bigger than the relay, you know :smile:
For the coil, that 1N4001 is more than enough. The back EMF is generated by the coil of the relay, its size/energy depends on the coil size and its polarity is in reverse than the original polarity of the current. So during a back-emf situation that diode will face it with the forward voltage, which is ~ 0.6V for most basic diodes anyway. If there would be significant energy then bigger diode would be needed due the current, not the voltage... The reverse voltage capacity of 50V matters only against the battery there. 50V vs. 1.5V - more than enough.
About the breakdown voltage: that means that the coil and the contacts are safely insulated to each other up to that voltage. Directly not related to sparks or arcs.
Regarding the arcs on the contacts: actually, how long lifetime are you aiming for? That design approach would be adequate to make those contacts last till the Coming of the Horsemen :oldbiggrin:
For this low load those contacts will be fine without any protection at all, unless you have significant inductance in the switched circuit.
If you want to stick with the cap&resistor, then the most simple SMD would be more than enough. At least that won't cost more than the relay... Also, the voltage of the cap is good at 25-50V: any common ceramic SMD will do.
Ps.: just noticed that you plan to use a LED to provide the necessary voltage drop between the relay and the battery? That's not a good idea, battery voltage does not count as constant. You might get that LED burned if the battery is full, while it just won't work when the battery is low.
  • Haha
Rive said:
:welcome:
For the coil, that 1N4001...
Although I'm someone that likes to play things safe, I had anticipated in the back of my mind that I had overthought this all, but I do appreciate you pointing that out, and of course in the charitable and well meaning manner that you did :)
but in regards to the capacitor, and resistor, I will definitely look for smaller sizes since the previous explanations that I found in other forums don't necessarily apply to my low signal/load application xD
But I do appreciate your explanation, that it has to do more with amperage (which I'm learning is pretty important, as well as the ampacity capacity of the medium through which said current passes through), and I shouldn't worry about breakdown voltage/insulation for this small load application (although I am curious about your statement on significant inductance in the switched circuit, specifically what would be specific cases where this would likely be a factor to be concerned about (is it relative to a specific current/voltage level, or a relationship between power and something else)? Are there any articles that you could point me towards to read up more on that? I apologize for asking more questions!)
I just had one more question about figuring out a specific way to calculate the size/energy of the back emf using the coil size. The closest formula that I could relating to this calculation was (what I believe is called) the Capacitive Current formula
I = C dv/dt
Is this correct or what other formulas could I use to more accurately estimate back emf values?
Thank you again for all of your help, it helped clear up so many things, it is greatly appreciated! And thank you for the greetings!
Ahahaha 😅 the entire circuit of the led button that controls the relay isn't directly connected to the battery (which is a portable charger; although there's another led button switch that is, that is connected in parallel with the switch that controls almost the entire device I'm building by acting as an on and off switch), that specific led button that controls the relay gets its power from a usb hub port that provides at most 2.4amps (which through my estimations, it seems only one and a half amp will be available to that hub) and I believe that hub has smart current limiting technology, but I'm not really positive on that, I have to double check since I'm still touching up on some areas in this total project.
in the schematics, the usb port that has a star is where the led switch and relay get their power from. But about current draws, although a battery or power source may provide more amperage than is required for a specific circuit, doesn't the resistance from the devices and the voltage of the circuit limits current draw on their own? Or in other words, that circuits and the devices will only draw on the current that they need despite what the battery provides? (and if this was the case, would that damage batteries since they are designed to drain at an appropriate rate?) Or is the amperage that the battery or power source provides forced onto the entire circuit which will wear out the entire circuit at a faster rate?
Oh! and here's the pdf specifications for the led button switches,
PDF for the Galco AL8 Illuminated Pushbuttons
Thank you for raising an important question, I'm going to look into this further!
shushi said:
I am curious about your statement on significant inductance in the switched circuit, specifically what would be specific cases where this would likely be a factor to be concerned about?
Capacitive loads are relatively easy, since any capacitor would be able to store the energy deposited after the circuit disconnect still at the same voltage: but inductive loads are different since they 'try' to maintain current without any concern about the voltage needed, and while doing this they have the backing of the energy stored in the magnetic field. Without suppression this might get pretty violent. A simple light tube choke coil can produce fat, 10kV arcs after disconnecting just a 5V battery from it... Of course real loads are usually not this thorny, but for example switching a small motor or an electromagnet needs some care.
For simple cases any search for 'flyback diode' will do. For advanced studies, it is 'snubber'. What I know about this is limited to the first part, with knowing when to call for an expert :sorry:
shushi said:
although a battery or power source may provide more amperage, doesn't the resistance from the devices and the voltage of the circuit limits current draw on their own?
With a battery you have to design for the maximal and the minimal voltage too, not just for the nominal (for a 12V lead-acid battery, it is 14V, 12V, 9V... Quite a range). And in case of LEDs it is important, since those are not linear with V and A. Slight change in voltage might cook the thing.
Just one more small remark on the USB charger. These are chargers: things are not necessarily expected to actually work when connected. You better check the output voltage and noise.
To use the "USB" label, devices must meet the USB specifications. here is an excerpt fromUSB Serial Bus Specification Revision 2.0, April 27, 2000, page 175 of 650:
"7.2.2 Voltage Drop Budget
The voltage drop budget is determined from the following:
• The voltage supplied by high-powered hub ports is 4.75 V to 5.25 V.
• The voltage supplied by low-powered hub ports is 4.4 V to 5.25 V."
So that is the voltage range you must accept.
Included in the same zip file is Universal Serial Bus Power Delivery Specification (394 pgs)
The full standard is available at:
http://www.usb.org/developers/docs/usb_20_070113.zip
It is a 37MB zip file of about 2000 pages.
(Bedtime reading for 7 months!)
Have Fun!
Tom
19K
29K
