Solutions to Matrix System with Integer Constraints
  • Thread starter Thread starter srodniki
The discussion focuses on determining the number of solutions for a system of equations represented by a matrix with integer constraints, where each row and column has specific non-negative integer sums. It establishes that without column restrictions, the number of solutions can be calculated using the product of binomial coefficients. The complexity increases when both horizontal and vertical constraints are applied, leading to fewer valid solutions. An example illustrates how to derive the total number of solutions based on specific values for the sums, emphasizing the need for a combinatorial approach to generalize the findings. The goal is to find a formula for the number of solutions, denoted as gamma, that satisfies the given constraints.
srodniki
Hi there,
I know that the number of solutions of a_{1}+a_{2}+...a_{n}=k where a_{i} are non-negative integers is just \binom{n+k-1}{k}.
Now, given a m\times n matrix with non negative integers a_{ij}, how many solutions are there for the following kind of system?
\begin{array}{ccccccccc}<br /> s_{1} &amp; &amp; s_{2} &amp; &amp; &amp; &amp; s_{n}\\<br /> \shortparallel &amp; &amp; \shortparallel &amp; &amp; &amp; &amp; \shortparallel\\<br /> a_{11} &amp; + &amp; a_{12} &amp; + &amp; ... &amp; + &amp; a_{1n} &amp; = &amp; k_{1}\\<br /> + &amp; &amp; + &amp; &amp; &amp; &amp; +\\<br /> a_{21} &amp; + &amp; a_{22} &amp; + &amp; ... &amp; + &amp; a_{2n} &amp; = &amp; k_{2}\\<br /> + &amp; &amp; + &amp; &amp; &amp; &amp; +\\<br /> \vdots &amp; &amp; \vdots &amp; &amp; &amp; &amp; \vdots\\<br /> + &amp; &amp; + &amp; &amp; &amp; &amp; +\\<br /> a_{m1} &amp; + &amp; a_{m2} &amp; + &amp; ... &amp; + &amp; a_{mn} &amp; = &amp; k_{m}<br /> \end{array}
The sum of each row and each column is constrained by the known non-negative integers k_{i} and s_{i}.
Without the column restriction we would have \prod_{i=1}^{m}\binom{n+k_{i}-1}{k_{i}}.
Thanks a lot.
I would say that the size of the solution decreases the more constraints you put on
the values. If my generic a_mn has to satisfy two equations ; horizontal and vertical,
then it becomes harder to find such a value.
Shouldn't there be a combinatorial trick? I mean here is an example for \left(i_{1},i_{2}\right)=\left(5,3\right) and n=3 . The system becomes
\begin{array}{ccccccc}<br /> s_{1} &amp; &amp; s_{2} &amp; &amp; s_{3}\\<br /> \shortparallel &amp; &amp; \shortparallel &amp; &amp; \shortparallel\\<br /> a_{11} &amp; + &amp; a_{12} &amp; + &amp; a_{13} &amp; = &amp; 5\\<br /> + &amp; &amp; + &amp; &amp; +\\<br /> a_{21} &amp; + &amp; a_{22} &amp; + &amp; a_{23} &amp; = &amp; 3<br /> \end{array}
Starting considering only the horizontal equations, trivially the solutions are any combination of the following two columns
\begin{array}{ccc}<br /> a_{11}\: a_{12}\: a_{13} &amp; &amp; a_{21}\: a_{22}\: a_{23}\\<br /> \\<br /> 500 &amp; &amp; 300\\<br /> 050 &amp; &amp; 030\\<br /> 005 &amp; &amp; 003\\<br /> 410 &amp; &amp; 210\\<br /> 401 &amp; &amp; 201\\<br /> 140 &amp; &amp; 120\\<br /> 104 &amp; &amp; 102\\<br /> 041 &amp; &amp; 021\\<br /> 014 &amp; &amp; 012\\<br /> 320 &amp; &amp; 111\\<br /> 302\\<br /> 230\\<br /> 203\\<br /> 032\\<br /> 023\\<br /> 311\\<br /> 131\\<br /> 113\\<br /> 221\\<br /> 212\\<br /> 122<br /> \end{array}
which has, as expected \binom{3+5-1}{5}\binom{3+3-1}{3}=21\cdot10 solutions.
Now let's consider also the vertical equations. For fixed \left(s_{1},s_{2},s_{3}\right) some of those 210 solutions will be our final solutions. First of all in order to have solutions it must be s_{1}+s_{2}+s_{3}=5+3=8, so only thes which satisfy this condition will contribute. For example, for \left(s_{1},s_{2},s_{3}\right)=\left(7,1,0\right) from the previous table we select only
\begin{array}{ccc}<br /> a_{11}\: a_{12}\: a_{13} &amp; &amp; a_{21}\: a_{22}\: a_{23}\\<br /> \\<br /> 500 &amp; &amp; 210\\<br /> 410 &amp; &amp; 300<br /> \end{array}
and thus we have two solutions. The number of solutions for all other possible \left(s_{1},s_{2},s_{3}\right) are
\begin{array}{ccc}<br /> s_{1}\: s_{2}\: s_{3}\\<br /> 800 &amp; \rightarrow &amp; 1\\<br /> 710 &amp; \rightarrow &amp; 2\\<br /> 620 &amp; \rightarrow &amp; 3\\<br /> 611 &amp; \rightarrow &amp; 4\\<br /> 530 &amp; \rightarrow &amp; 4\\<br /> 521 &amp; \rightarrow &amp; 6\\<br /> 431 &amp; \rightarrow &amp; 7\\<br /> 422 &amp; \rightarrow &amp; 8\\<br /> 322 &amp; \rightarrow &amp; 9<br /> \end{array}
(permutations of the s give the same number of solutions).
How would one generalize all this? If \gamma is the number of solutions of the general system, this identity is valid:
\sum_{s_{1}+..s_{n}=k_{1}+..k_{m}}\gamma\left(s_{1},..s_{n};k_{1},..k_{m}\right)=\prod_{i=1}^{m} \binom{n+k_{i}-1}{k_{i}}
The point is to find that \gamma...
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
