Observing wavelength at an angle
  • Level: Undergrad
  • Thread starter TheCanadian
    Angle Wavelength
4 replies · 1K views · last reply
TheCanadian
I recently came across an equation stating that ## \lambda_{ob} = \frac{\lambda}{cos(\alpha)} ## if ##\alpha## is the angle the observer is relative to the wave's direction of propagation. I guess I can kind of understand that a person perpendicular (i.e. ##\alpha = 1##) would see the normal wavelength, but am just failing to understand what exactly it even means to observe the wavelength at an angle. How does standing perpendicular to the wavefront make it look like the wave has an infinite wavelength?
It does not, but if you look at the phase difference between different points of your "observation plane", they all have the same phase. This equation tells you how far apart maxima (or specific phases) are on your observation plane. I don't think it is useful to call this "wavelength", however.
Hmmm...do you mind expanding on that? How exactly does the maxima look infinitely far away from each other if you're simply looking at the wave perpendicular to its direction of propagation?
Also, isn't the distance separating maxima essentially what an observed wavelength is?
The distance along the observation plane is "infinite" (you see the same maximum everywhere at the same time). The distance along the travel direction (the real wavelength) does not change.
Thinking of the wave as stationary and myself moving against the wavefront at the angle ##\alpha## really helped! Thank you!
