Obtain a fourier series equation from a given graph
The discussion focuses on deriving a Fourier Series Expression for a periodic function defined as f(x) = -x for -1/2 < x < 1/2, with a period of 1 and a magnitude of 5. Participants confirm that the function's odd symmetry means the Fourier representation will only include sine terms, eliminating cosine components. The coefficients for the sine series can be calculated using the integral bn = (2/T)∫Tx(t)sin(nωot) dt, with the integration limits adjusted to 0 to 1/2 for this specific function.
  • Understanding of Fourier Series and its components
  • Knowledge of periodic functions and their properties
  • Familiarity with integral calculus
  • Basic understanding of odd and even functions
  • Study the derivation of Fourier Series coefficients for odd functions
  • Learn about the properties of sine and cosine functions in Fourier analysis
  • Explore the application of Fourier Series in signal processing
  • Review examples of Fourier Series in different periodic functions
Students and professionals in mathematics, engineering, and physics who are interested in signal analysis, particularly those working with Fourier Series and periodic functions.
ashifulk
The problem statement:
Obtain a Fourier Series Expression Form from the above graph:
I can't post the graph, so I will describe it. It's a periodic function with period 1 and magnitude 5. The equation is the following: f(x) = -x, -1/2&lt;x&lt;1/2
I'm really stuck at trying to obtain a series expression. I really don't know how to start this problem. If anyone can tell me how to approach it I would appreciate it.
You've identified the period so you should be able to find the fundamental frequency. The Fourier series will represent the signal as a sum of sines and cosines at the fundamental frequency and its harmonics. The coefficients of the sinusoids are found with the Fourier integral.
There is a shortcut in this problem. The function is odd... do you know what that tells you about the sines and cosines in the Fourier representation?
Since the function is odd the Fourier representation will only contain sines...
I think I found the solution. On this page (http://www.sosmath.com/fourier/fourier2/fourier2.html) it has the Fourier representation of the sine series. But on there the intergral for bn goes from 0 to pi, is that because they are assuming that that is the half of the period of the sine function?
If that's true, in my case I just have to solve for the intergral from 0 to 1/2 correct? And then plug bn back into the series expansion formula...?
Yes that's right. Any cosines added to the result would destroy the odd symmetry so no cosines can be involved in representing the original function.
On that page they've assumed functions have had their periods normalized to 2pi and so that they are periodic from -pi to pi. They integrate over half the period (0 to pi) instead of the whole period (-pi to pi) because the integrand is the same from -pi to 0 as from 0 to pi so they just integrate from 0 to pi and double it.
Don't be afraid to apply the equations yourself :)
b_{n}=\frac{2}{T}\int_{T}x(t)sin(n\omega_{o}t) dt
  • · Replies 26 ·
