Creating a Multi-Radio Wave Demonstration: How to Find the Right Machine
The discussion focuses on the challenge of finding a machine that can emit multiple radio waves simultaneously for a demonstration. Participants suggest using devices like Diplexers or Triplexers to combine RF sources, while emphasizing the need for clarity on the specific application and frequency ranges. The original poster aims to simulate binary signals using radio waves, akin to how electrons function in computers, and seeks a single output device that can send similar frequencies to multiple receivers. There is a consensus that careful planning and understanding of RF technology is essential for successful implementation. Overall, the conversation highlights the complexities involved in creating a multi-radio wave demonstration.
Charles_The_Erlich
Is there a machine that can emit multiple radio waves simultaneously? I am trying to create a demonstration, but it requires multiple radio waves at once and cannot find any machines that can do so.
:welcome:
Do you mean a wide frequency spectrum? White noise in the RF range satisfies that.
I think we need to hear more about your definition of multiple radio waves?
Welcome to the PF.
You can just use a Diplexer or Triplexer to combine multiple RF sources into one coax output. Can you say more about your application? What frequency ranges? Do the combined waveforms feed a Spectrum Analyzer or an antenna?
EDIT -- Beaten out by the guy with the mustache again! :smile:
anorlunda said:
:welcome:
I need to output the, preferably same, frequency multiple times from the same source to multiple things at the same time.
I essentially need 1 device to send out multiple signals that can be recognized by multiple receivers, one receiver for each signal.
Oh, then just use the Triplexer in reverse! :smile:
Welcome to the PF.
I would like something like a Triplexer, but can operate with multiple of the same frequencies or very close.
anorlunda said:
:welcome:
I plan on having insulators of sort so that the signals do not interfere with each other. The problem is that i need 1 source to output the same or very similar wavelengths because the low frequency waves are easier to insulate against. The wave outputs need to be just strong enough so that a small receiver can pick up the signal it is designated to recognize. Think about binary that commands computers as to what to do. I wish to have the waves show that a signal is present or not resulting in a 1 or a 0. I need 1 output device that outputs the same or similar waves simultaneously to different areas.
Can you say more about your application? I get the feeling that there is an easier way to accomplish what you want to do.
Likes sophiecentaur
I want to simulate the what electrons do in computers with binary with radio waves instead. Binary just shows that the circuit is complete and is read by computers to perform actions. I want to create a large scale version of this with radio waves taking the place of the electrons.
Ah, thanks. How familiar are you with basic computer architecture and circuits? Are you familiar with the concept of Memory in computers? Do you have a proposal for how to simulate Memory functions (registers, etc.) with this radio wave demo?
I am semi-familiar with such components. I know how to program and know some stuff about how the computer physically works. I do not have a clear idea as to how everything works together, but my intention is to essentially create a large-scale example that registers the signals, instead of a creating a small-scale, more functional version of it. I have only started working upon this as of yesterday, so i do not have everything worked out yet.
Radio waves are already used in all computers to manage electron movements. The high-frequency circuits use (confined) RF waveforms for the clocking and control signals that dictate the behavior of the electrons in gates, registers, and other computer structures. High-frequency clock lines on ICs can be thought of as confining the RF waveforms to transmission lines, much like coax cable does this on a macro scale.
Then you are probably familiar with the concept of "clock trees" for distributing the system clock RF waveforms throughout a computer. That sounds a lot like what you are asking about, but you are still missing the registers at the end of the clock trees for managing the actual data, IMO.
something in there doesn't make sense
you said ... I need to output the, preferably same, frequency multiple times from the same source
you only need ONE source for multiple receivers
Again as Berkeman and others said
What EXACTLY are you trying to ackieve
I think you need to specify more exactly what you actually want to achieve here. What actual RF frequencies did you want? Are you planning to monitor the resulting signals from a distance?
This sounds a bit like a local area network (WiFi, perhaps) where the outputs from a number of computers are monitored by another computer overt s Radio Frequency Link. This is already done by a server which can supply many computers with information (files / images etc) according to the signals it receives from them. This is very complicated but familiar technology.
Perhaps you could draw a diagram of what you had in mind and what you actually want to achieve? Just connecting things up at random has a habit of giving disappointing results so some serious planning is needed.
  • · Replies 17 ·
  • · Replies 39 ·
