- 4,878
You misunderstood what I said. Saying that a particle has a fuzzu position means that it actually _has_ this position independent of any measurement, but that its value is meaningful only up to an accuracy determined by the uncertainty relation. The position is given not by |psi|^2 but by xbar=psi^*x psi, with an absolute uncertainty of sqrt(psi^*(x-xbar)^2 psi).SpectraCat said:You are the one who started telling Varon (on the interpretations poll thread I think) about how the position of a particle does exist, but is not well-defined (you used the term fuzzy) until a measurement is made. What do you use to describe the existence of the particle position prior to the measurement if you don't use |psi|^2?
Measuring the position gives a value statistically consistent with this and the measuring accuracy, but does not change the fact that the position remains fuzzy. You cannot read from your meter that the position is at exactly x.
