One dimensional Elastic collision of two identical particle
In a one-dimensional elastic collision between two identical particles, the velocities are typically swapped, which is the standard solution. However, a valid alternative solution exists where neither particle changes its velocity, representing a scenario where one particle is static and the other moves past it without interaction. This interpretation highlights that if a collision occurs, momentum is transferred; otherwise, it results in a miss. The discussion emphasizes the importance of understanding the physical implications of mathematical solutions in collision problems. This insight reveals that both outcomes satisfy the conservation laws, despite being less commonly acknowledged in textbooks.
L0r3n20
Hi everyone. I've a question that i wondered since the high school. Let's take two identical particles (same mass) that collide frontally. Assume it's an elastic collision. We have to conservate both the momentum and kinetic energy:
v_1 + v_2 = v'_1 + v'_1
v^2_1 + v^2_2 = v'^2_1 + v'^2_1
(where primes denotes the velocities after the collision). Now I do know the solution: the velocities are swapped among the two particles and here comes my question: since the one I wrote is a symmetric system, why should I not accept the solution where the two velocity are not swapped?
You should accept that as a valid solution. What physical situation does it represent?
Every book I checked does not take into account such a solution. In fact, in order to obtain the desired solution they dived by (v_1 - v'_1) (and same for the v_2). As a physical solution I imagined a moving particle colliding with a static one. In such a situation, the solution where each particle keeps its velocity is represented by the first particle hitting the second one that remains still while the first one goes on. Am I right? Is this possibile?
It's simpler than that. Imagine particle B is at rest and particle A is moving towards it at speed ##v##. Particle B closes its eyes and afterwards is still at rest, while particle is moving away at speed ##v##. What has happened? It's very simple!
If you haven't got it yet, here's another clue:
Ok thanks Perok that's very illuminating! :D
In other words IF there is a collision THEN we can assume momentum is transferred, ELSE we have a miss, right?
Yes. I'm suprised none of the books mention this, as it's a good example of having to interpret what is, after all, a perfectly valid mathematical solution. The equations are equally satisfied with no change to either particle.
I suppose that, being a 1D problem, you cannot admit a miss...
Both of you got a point. Now you convinced me. Many many thanks.
  • · Replies 32 ·
